Question about Video Game Consoles & Games
My machine keeps whinding the tread around the bobbin. It gets hung up and make a large not between the needle and the bobbin. the tread get a large glob and won't sew. The tread keeps breaking. won't sew. Its a new machine about a year old.
    President:
  • 778 Answers
Hello Dleesego,
It sounds to me like your machine needs to be cleaned by a authorized service tech.. One of the components that the thread travels has probably gotten fouled with thread and isn't rolling freely causing your thread to "glob" up. If you are handy, you may be able to find (through the manufacturer's support site) the schematics for it, and use those to diagnose the most likely point of the hang up.
Good luck.
PS: You posted this in the "Video Game Console, Troubleshooting section.
Posted on Feb 28, 2008
How to time a singer 758 sewing machine? The needle is not picking up the bobbin tread.
remove all the plates around the needle and bobbin cover
slowly turn the machine until the needle is right at the bottom
not continue turning until the needle just starts to come back up
At this point the hook of the bobbin case should be just at or close to the needle eye
The bobbin position cannot be altered as the needle is the adjustment
That is done by loosening of the clamp in the needle bar and moving the needle crank up or down to get the correct position and then re-clamping the screw
Note here--make sure that you have the correct needle length in the machine as needle lengths do vary for different applications .
search -- needle and hook timing for singer sewing machines-- to get illustrations on how to do it
May 27, 2018 | Singer Sewing Machines
Manual for the wimsew thread not picking up around the bobbin
Try installing a brand new needle. If it is still not picking up the bobbin thread, then the needle/hook timing make be off. Take it for service.
May 26, 2016 | Sewing Machines
How do I wind the bobbin?
There are several ways. On most machines you put the empty bobbin on the spine over the bulk of the machine on the right hand side. Twist some threads around the bobbin to get started, then put the thread through the thread loop above the shuttle area on your left side. That keeps the tread tension right. There is a gear the clicks into the bobbin. You push that closed. You will have to release the clutch by turning the large wheel on your right hand side. Not hard to find and it usually is hand size. It is the one that goes around and around when you are sewing. Grasp it firmly and turn the top toward you. This will prevent the needle from going up and down when the thread is pulled onto the bobbin. Don't forget to tighten the large "wheel" when you are done.
Feb 24, 2015 | Sewing Machines
I have a Brother 750D innov-isi think he tenchion
If the thread is pulling through the top of the fabric slacken off the top tension to about 4 and tighten the bobbin tension slightly by turning the screw on the bobbin case about a quarter of a turn clockwise and test.
Apr 06, 2010 | Brother SE-270D Computerized Sewing...
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Sep 23, 2009 | Brother CS-100-T Computerized Sewing...
I am getting bird nests under my embroidery hoop. It seems that there is an issue with my the bobbin because all the tread in the bird nest is not the bobbin thread. It has done it three times in a row and...
Anytime I have had it happen it was because my machine wasn't properly threaded. The first place you run the thread through it has to click into place in two places. If it misses one it will birdnest.
Aug 29, 2009 | Singer CE-200 Quantum Futura Computerized...
Top thread keeps getting wrapped around bobbin case on LX-3125
You should hold the end of the thread coming through the needle until the thread has grasped the bobbin thread.
Jun 30, 2009 | Sewing Machines
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle picks up bobbin thread but then thread gets stuck
I had exactly the same problem on the exact same model 3205FA. I'm not an expert, but have a little experience on solving my wife and daughter's sewing machine mechanical problems. I would suggest the following: A. Page 6 of the owners manual see item # 1...to be precise it is 1 1/2 times around. B. Page 7 at the bottom, Make sure the bobbin tension spring is set so that there is tension. When holding the tread the bobbin shouldn't unroll. If jiggled about 2-3 inches the bobbin should release about 1/3 of that distance. C. Page 8 at the bottom, ill. # 2. There are two flange holders and screws that hold the bobbin case in position located at about 5 and 7 o'clock. Make sure both screws are tight. This is important. D. Make sure the thread is treaded through the upper tension adjustment properly. See page 9 # Illustration C. Terrible illustration. Keep the dial generally in the green range. E. Put in a new needle, the needles that come with the machine are just short of terrible. Wouldn't hurt to buy good top quality needles for the machine.
Aug 22, 2006 | Necchi 3102 Mechanical Sewing Machine
Video Game Consoles & Games Logo
55 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
