Question about SanDisk Sansa m240 MP3 Player
Hidden file after the player kisses the ground :(
Hello!
A BIG thankyou for your time and expertise.
I accidentally dropped my Sansa m240 and, naturally, the file that was recording at the time stopped. My problem is that when I turned the machine back on, the file (VORC002) seems to have disappeared. When I record a new file, I noticed that it has taken the same title as the one which vanished I am grateful for any advice...I really hope that I'll be able to retrieve the information. Is it possible that the data may be sitting on the player still? I used a program which reveals lost and deleted files to try to find it but, unfortunately, no joy :(
Thanks in anticipation,
Sally
  • 42 Answers
Well try update the whole thing it will be as good as new.
Goto this webpage to do so:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
or
try to recover you player from this site :
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
These might help buddy.
Posted on Mar 07, 2008
There are songs on my San Disk Sansa M240 MP3 player that do not show when connected to the computer. I wish to delete these songs. How do I get them to show on the computer program and delete?
ok
See if that your folder options is not set to (do not show hidden files and folders .
Follow these steps to check it:
1. open control pannel.
2.Double click folder options then click view
3. then scroll and locate Hidden files and folders.
4.select show hidden files and folders.
5.Also untick the hide extension for known files type:
ok
cheers
uttam
Jan 13, 2010 | SanDisk Sansa m240 MP3 Player
There are several songs that are on the m240 that are not showing when you look at it's files - how are these hidden?
If you added songs to the device in MSC mode, then switch to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching from MSC to MTP mode or vice versa.
For older players - e200v1, c200v1, c100, m200 - the files become hidden files if the modes are switched. An easy workaround is to edit the folder options to show hidden files.
STEP 1 - Edit the folder options of the computer to show the hidden files
Windows XP:
1. Double-click My Computer.
2. Under the Tools menu, select Folder options, then click the View tab.
3. Under Hidden files and folders option, select Show hidden files and folders.
4. Uncheck the Hide protected operating system files (Recommended) check box.
5. Click Apply, then click OK.
Windows Vista:
1. Double-click Computer.
2. Click the Organize button on the upper left corner.
3. Click Folder and search options.
4. Click the View tab and select Show hidden files and folders.
5. Uncheck the Hide protected operating system files check box.
6. Click Apply, then click OK.
SOLUTION 2 - Perform a Check Disk.
STEP 1 - Switch to MSC mode
1. On your Sansa player, switch the USB mode to MSC.
2. Connect the Sansa player to the PC.
STEP 2 - Perform Check Disk
1. Locate the Sansa player under My Computer.
2. Right-click the removable drive associated with the Sansa player, and select Properties.
3. Click the Tools tab, and then click Check now.
4. Click to select the Automatically fix the file system errors and Scan for and attempt recovery of bad sectors check boxes.
5. Click Start.
See also this tip on what it all means http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
Jan 02, 2010 | SanDisk Sansa m240 MP3 Player
I dont have a disk or manuel for my sandisk sansa m240 how can i download music to it? I have the usb cord tho.
Follow these steps to drag-and-drop music files to your Sansa player:
1. Connect your Sansa player to your computer.
2. Open Windows Explorer.
3. Double-click on your Sansa player.
4. Double-click Internal Memory if you are using WMP 11 or double-click
Media if you are using WMP 10.
5. Drag and drop music files from your computer to the Sansa player’s MUSIC
folder.
Dec 10, 2008 | SanDisk Sansa m240 MP3 Player
How can i back up my m240Sansa firmware
check for a file that will end in the extention .bin. u may have to enable view hidden files and folders in the folder options in the tools drop down menu. copy that. then, if you need it back, just paste it back into the mp3 player
Apr 19, 2008 | SanDisk Sansa m240 MP3 Player
Deleting songs etc on my m240
Maybe your files are hidden.
Try to unhide them in windows folder option.
goto my copmuter >
look all the way on the top and press "tools" >
then press "folder option" >
then goto the "view" tab >
then look down at "Advanced Settings" and see the title "Hidden files thumbnails" >
then put the option "Show hidden files and folders".
See is this helps .!
Mar 05, 2008 | SanDisk Sansa m240 MP3 Player
Lost my instructions to my sandisk sansa m240 mp3 player
I looked long and hard and was able to find the answer.. It should not be this hard but here you go; Its the link to the pdf file:
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_ug_Eng_m200.pdf
Glad to help!
Jan 10, 2008 | SanDisk Sansa m240 MP3 Player
Scandisk sansa m240 mp3 player
You can manually transfer files thru My Computer>Device Name (m240). Just drop the files, no folders, into the device. Best of Luck.
Oct 04, 2007 | SanDisk Sansa m240 MP3 Player
Sandisk sansa m240 mp3 player
You can connect the device to your computer and manage it thru "My Computer. Open My Computer, then open the device (i.e. Sansa m240). Inside there is a Music folder, you can delete them from here. You can also drag songs here to transfer to the player. If you are not able to see the "music" folder, you may need to enable "Hidden Files and Folders" on your computer. Best of Luck.
Sep 06, 2007 | SanDisk Sansa m240 MP3 Player
I can't delete files off of my mp3 player!
Hi, This is taken from another post, but might work for you as well: 1. Take the battery out of the Sansa player. 2. While the battery is out, plug the Sansa m200 player into another USB port, preferably a rear one or a self powered USB hub, on the computer. 4. If the screen reads ?USB Connected? when the Sansa player is plugged in with no battery, unplug the Sansa player. 5. Hold the "Menu Button" (Power Button) for 45 seconds. 6. Connect it to the computer again (still without the battery). 7. If the screen once again reads ?USB Connected,? disconnect the player and insert a new battery which has never been previously used. 8. Try powering on the player. If the above procedures (power cycle) didn't work, please repeat the process again but now hold the power button for 2 minutes and wait for at least 5 minutes before plugging in new set of batteries.
Jan 12, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
