Question about Dishwashers
Kenmore Dishwasher won't start
I have a Kenmore Elite dishwasher - model# 665.16933000 that does not react when I press the 'start' button. I can select wash cycles, and the appropriate time appears, but pressing the 'start' button doesn't kick it on, and after 30secs all lights go dead. Ran the diagnostic mode and all cycles seemed to work fine, even the heating coil was hot, and water was heard entering and draining. Assumed it was the control board, but have a suspicion it may be a bigger issue since the few cycles that did work, prior to it going dead, did not wash well and didn't even dissolve the detergent tablet (very unusual). Anybody have a solution for this problem? would like to hear from you. Thanks in advance.
  • 2 more comments
  • apotts Feb 28, 2008
    I originally also thought this may be the issue, however, I ruled it out once I saw the diagnostic mode would not run with the door open, but DID run with the door closed. To me that was an indication the door circuit was in proper working order.
  • apotts Feb 29, 2008
    As for the suggestion of a faulty door latch control, I ruled it out once I saw the diagnostic mode would not run with the door open, but it DID run with the door closed. To me that was an indication the door circuit was in proper working order
    Turning off the power to the unit overnight was the first thing I tried, unfortunately it didn't solve the problem.
  • apotts Mar 03, 2008
    Thanks for everyone's input. I tested the circuit board, and it does seem that part of the board is not receiving voltage. Very strange, since all the LEDs and even the diagnostic mode seems to be in perfect working order. The "Start" button control must be on the part of the board that's not functioning.
  • 259 Answers
Here is a trick I have found on the net:
Try pushing the normal wash and heated dry buttons back and forth This will reset the dishwasher. Not shure if it for your model but it may work. Hope this helps! :}
Posted on Feb 29, 2008
  • 796 Answers
Anyway, you'll have to take the door apart to the get to 'em. Once you do, look up top and they're located here. When you pull out the whole door latch assembly, it all looks like this here.
Kenmore Dishwasher won't start - 00092487.jpgNow, if one of these door switches are bad, you'll usually be able to see a burnt wire and one of the switches will be obviously AFU 'cause it won't click when actuated. 'Course, it's always a good idea to verify with your ohm meter. If one of the switches are fried, don't be a bonehead and just change the bad switch. Save yourself some trouble down the road (and avoid an unpleasant dishwasher fire) by changing both switches and the wire harness. You can buy the whole replacement kit here.
  • isaac johny
    isaac johny Feb 29, 2008
    Next Most Common Troublemaker: Blown Thermal Fuse
    The thermal fuse is located in the control panel, called out as item #18 in this picture. You can check it with a simple continuity test.
    Or you can jumper it out to see if the dishwasher will start running
    normally. If it's bad, you can order your replacement thermal fuse here.
  • 4,102 Answers
Hi have you tried switching it off at mains for more than 30 min to reset the dishwasher itself this can solve your problem let me know if you have tried this or not ok
  • paul proctor Feb 29, 2008
    Hi thanks for replying and if its been turned of and made no differance then it could be on of a couple of things it could be that its got a build up of limescale in the jets causing the water pressure to rise and this causes the dishwasher to shut off as a safety feature.
    If this is the case you can buy products that remove lime scale but it will require you removing all the jets and pipes to clean them through this could be your problem.
    But it could also be a fault on the circuit board itself if this is the case then the board with the fault will need replacing.
    How long have you had the dishwasher for??
    Brigadier General:
  • Dishwashers Master
  • 3,614 Answers
Check all the cover is properly fit in when the dish is loaded, sometimes it can happen that some obstruction in closing the cover makes the washer won't start.
Thanks
Posted on Feb 28, 2008
  • micromaster
    micromaster Feb 28, 2008
    You went to run the dishwasher see to it that you closed the door. If it didn't latchet and made sure the shelves were completely in or then tried shutting again.You checked that the door was closing and upper latchet was aligned.
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
My kenmore elite ultrawash dishwasher, model # 665.16289402, will not start. The green clean light keeps blinking and when you go to push start after selecting which wash program it does nothing.
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Elite 15962990 will not start
So far, I'm not very impressed with this website. I posted a problem with a Kenmore Elite 15962990. FixYa emailed me back, saying: "We wanted to find out if you still need a solution for the Kenmore 24 in. 15932 Built-in Dishwasher Problem". So now I'm confused. I'm supposed to trust advice from somebody who can't even get the model number right? And FixYa keeps telling me I'm dealing with a top load clothes washer instead of a dishwasher.
Anyway, the problem still exists. I know there must be some way to reset it or put it in "maintenance mode". But none of the button sequences I saw online will work because my specific model does not have the buttons mentioned.
Feb 10, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
619 people viewed this question
Top Dishwashers Experts
