Question about Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor '' no power''
Model no.:AL1916W A
Version:AL1916W Asd
P/N:ET.C16WA.A01
Mfg:Apr 2007
S/N:ETL800C025716093344031
SNID:71603768440
  • 2 more comments
  • EmaJ Apr 03, 2008
    Totally no power! I repaired myself the power supply (DC-DC inverter) but there were no power indicator and backlight.
  • digitaluk Jun 26, 2008
    my al1916 will not power on, after checking the power supply ive
    noticed that part U101 is blown (melted) can someone tell me the exact
    part so i can put a replacement in as there are no letters to tell me
    which part this is as its melted and ive looked everywhere for the
    service manual. im pretty sure its a voltage regulator of some sort.
    also notice what could be a very slight bulge at the top of the c114
    cap (400v 100uf)
  • Anonymous Nov 19, 2008
    I also have an AL1916W that has the same problem. Monitor doesn't turn on. Where on the circuit board is the component that you said was blown?
  • n4zhg Mar 08, 2009
    Left the monitor on overnight, found it dark in the morning. No power light, not working.
I'm having the same problem and it turns out to be the main board.This Service guide is for Version 1.0 but turned out to be helpful
http://www.abcelectronique.com/forum/attachment.php?attachmentid=12292
Posted on Apr 21, 2009
There was a busted fusible coil in series with the main line supply. Changed it with an ordinary fuse. There are available voltages for 5V and 12 volts but still there is no power indication on the panel and never turns on. I checked the backlight but no output power. the system control has power supply of 3.26 volts. What really the problem of this unit?
Posted on Apr 04, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
Acer AL1916W 19" LCD Monitor '' no power''? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
490781400200R ILPI 031 Acer 790691400610R Power Supply Backlight Inverter
Posted on Dec 11, 2014
  • 6 Answers
U101 is a FSDM0565R ??? DO NOT KNOW THE END BIT. FAIRCHILD, SEMICONDUCTORS, POWER SWITCH. FARNELL SELL THEM. BUT THERE ARE TWO CHOICES, DONT KNOW THE DIFFERENCE.
Posted on Jul 24, 2009
I have problem my acer moniter model no al1916w a was off after 5 second during power on but its led is glowing green
plese send to resolve this problem
my e mail is bassam2005bassam2005@yahoo.com
Posted on Jul 22, 2009
Monitor ACER Model AL1916W Problem
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 16, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Antitheft enable tobe disabled
Press CTRL + ALT + DEL to kill this process, uninstall unwanted programs from your computer and clean Windows registry using some reliable software such as Reginout. Thanks
May 13, 2010 | Acer AL1916W 19" LCD Monitor
How do you hook up sound to the computer. I have
The ACER AL1916W does not have built-in speakers, you need to get powered speaker system for your PC.
This is the spec of the AL1916W: http://reviews.cnet.com/lcd-monitors/acer-al1916w-lcd-display/4507-3174_7-31652355.html?tag=mncolBtm;rnav
Mar 30, 2010 | Acer AL1916W 19" LCD Monitor
there is someone trying to still your data/information in your computer, disconnect the computer from the network immediately.
Mar 22, 2010 | Acer AL1916W 19" LCD Monitor
On a Acer AL2016w and the 2017 it is the far right larger button with the light in the middle of it.
I'm almost positive the AL1916 is in the same place
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
SCHEMATIC LCD MONITOR AL1916W FROM ACER
Schematics are in the Service manual here → https://www.mk-electronic.de/hersteller/PDFDokumente/Acer/Display%20Product(DP)/19/AL1916Wc.pdf
Oct 12, 2008 | Acer AL1916W 19" LCD Monitor
Problems with monitor Acer AL1916w
I'm using the Al1916W and it looks great at 1440 x 990. Make sure you have the latest Screen card drivers installed.
Apr 03, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor color has changed to blue
Hey Buddy
My AL1916W was having same problem, its due to faulty IFB which cannot save colors after pressing reset, get it replaced from acer, if its in warranty, acer will replace ur LCD within a week.
Mar 15, 2008 | Acer AL1916W 19" LCD Monitor
No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Jan 05, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
2,595 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
