Question about Xerox DocuColor 12 Printer
10-359 I have problem with dc12. Stat. indicator10-359 I was Rip -thirmister ------ No change I was Chk fuser in other machin, fuser is ok. What I want Do ? Thanx Kishor
    President:
  • 2,072 Answers
Make sure all the connections are in good shape. Look for a broken or slightly burnt connector.
A pinched wire may be the problem.
And the over heat thermistor may have blown.
Its a fuser sensing code. You may have to replace the fuser itself.
Posted on Feb 28, 2008
    Problem Solver:
  • 8 Answers
Initial Actions
Refer to BSD 10.2 and 10.12 for the following procedure.
Perform the following:
1.Open the Drawer and extend it to the service position.
2.Remove the Oil Cartridge ( PL 8.1 ).
3.Remove the Front Cover ( PL 8.1 ).
4.Remove the Top Cover ( PL 8.2 ).
5.Check the Heat Roll Control Thermistor for cleanliness, damage and excessive wear at the point where the Thermistor contacts the Heat Roll. If the surface of the Thermistor is worn, replace the Heat Roll Control Thermistor Inspect the surface of the Heat Roll for excessive wear due to the Thermistor. Replace the Heat Roll if necessary
6.Check the Drawer connector at the rear of the Fuser for damaged pins
Posted on Mar 10, 2008
Greetings: i have A sharp 1641CS and it indicates
A H4 error code could be the fuser lamp or the thirmister or the thermal fuse. The lamp may cost $20.00 the others may be $10 to 15 dollars each
Jun 16, 2010 | Sharp AL-1641CS Laser Digital Copier
Dc 12
Did you check the sensors?
Feb 28, 2008 | Xerox DocuColor 12 Printer
CAN WE RUN 2 MACHINES OFF ONE RIP?
you can not run two device from one fiery this would cause job processing and spooling issues.
Jul 28, 2009 | Office Equipment & Supplies
Printing to a Xerox DC12/DCS50
you can't print via serial to it. You will have to check the settings in your rip to see what the ip address is. Lights will blink all the time to indicate it is on a network, its just not talking to it. Then you go into your add printers section click the + sign and it should come up in there if the ip address is in line with your mac ip
Dec 16, 2008 | Xerox DocuColor 12 Printer
Fow to you change a fuser nip clutch on DC12
With extreme difficulty if you don't know your way around the back of a dc12. Whats wrong with your machine?
Sep 04, 2008 | Xerox DocuColor 12 Printer
XEROX WORKCENTRE PRO 40
What code is it given? Is it trying to warm up and gets warm and then codes out???? You may have a short in your thirmister ... Try to clean the sensor it self of biult up toner. Then reinstall the thirmister and test the copier. You may have to replace the thirmister... Good Luck
May 12, 2008 | Office Equipment & Supplies
Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Feb 15, 2008 | Sharp AR-M237 Copier
Xerox DocuColor 12 Printer Logo
313 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
