Question about Vacuums
I have a self propelled Royal Dirt Devil vacuum model number 087900 and it goes backward fine but forward has to be pushed so hard it's impossible. Is this a switch? Do you know about how much the part would cost and can it be done by a beginner. We fix a lot of things ourselves but we aren't mechanics by no means. We put a brand new belt on it. I don't think it can be put on backwards and brush turns fine. Where is the switch? Use layman's terms.
  • jandl63 Feb 29, 2008
    We put a new belt on it from the vacuum store and the brush works fine when you lay it on the side and watch it. It just won't go forward like something is pushing against it. Thanks for suggestions.
    We took it apart and it looks like a cord (is this the cable?) and where and how do we adjust it Jim
    President:
  • 1,673 Answers
You might try a new belt and/or brush roll. The brush roll is what helps pull a vacuum forward, the power drive helps, but if the brush isn't turning like it should, then it will hinder forward motion. The belt may look ok, but they stretch to the point that under load they won't drive the brush roll.
Posted on Feb 29, 2008
  • Lauren Junge
    Lauren Junge Feb 29, 2008
    on some models there is a 2nd belt, it is for the drive, on some that use a cable that runs from the handle to the drive unit, you can adjust the cable so that it moves both directions, so maybe it just needs to be adjusted. Without looking at it is hard to know exactly what the problem is.
  • Lauren Junge
    If this is a cable, then at the end is where there should be an adjustment to either loosen it or tighten it.
How do I put attachments on classic handheld dirt devil?
They would have to be attachments compatible with that particular model, and they usually come with it as original equipment. but you might try a Google search for Dirt Devil (model number) attachment kit. Also found this on ebay:
Original Dirt Devil by Royal Mini Attachment Kit Some Parts New Un Opened...
May 09, 2016 | Vacuums
The brush in my dirt devil (royal) vacuum model #130005 plant j does not work when the vacuum is turned on
Replace the rubber drive belt to the brush after confirming that the brush is turnign freely.
If brush is stuck remove and clean.
Jul 14, 2014 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Self propel not working
Make sure the replacement belt was the right one/size.
Make sure the self propelled is on at the handle. If you replaced the flat belt and it still pushes hard the most common problem is a broken power drive cable or actuator arm. Put the handle down and move the power drive handle forward and backward. If it moves freely watch by the headlight for the cable to move the actuator at the base. If the cable is in tact it should move the actuator. If it is broken the actuator will not move. If the actuator is broken the piece of plastic holding the cable will let the cable slide or it may be broken off completely. Replace whichever is broken.
If the cable system is ok and the belt is correct you may have a bad powerdrive assembly. I will include links to correct replacement parts.
Actuator
http://www.vacuummedic.com/product.php?id=363
Cable
http://www.vacuummedic.com/product.php?id=362
Belt
http://www.vacuummedic.com/product.php?id=6
Good Luck!
Aug 23, 2012 | Hoover U6446-900 WindTunnel Bagged Upright...
The vacuum is not rolling easily. It "drags" on the rug.
Hi There,
When a Hoover Windtunnel becomes hard to push, this usually indicates that self-propelled has stopped working.
When this stops working, it can be caused by several things. The first, most common problem is that the belts have either broken, or stretched to a point where they no longer engage the self-propelled mechanism. In order to verify this, simply make sure that the machine is set to the Carpet setting, turn the machine on, and turn it over on it's side with the handle release pedal reclined (make sure it's not in the upright position). Is the brush at the bottom of the vacuum spinning? If no, this definitely indicates that your belts have gone bad and need to be replaced. There are two belts on your machine, one controls the brush, the other controls the self-propelled mechanism. We've shot a helpful video that walks you through step by step on how to replace the belts.
This is by far the most common problem that we see on your particular model:
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
May 06, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a dirt devil vacuum made by Royal. It is a
You need to change the belt. If it is self propelled it will have two belts. You can find the type of belt you need in the manual and then you can get the belts here:
Dirt Devil Replacement Belts
Nov 06, 2009 | Vacuums
Our dirt devil vacuum is blowing out air instead of pulling in air.
my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
Aug 29, 2009 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 03, 2008 | Dirt Devil M088300 Upright Vacuum
E drive problem. Self propelled feature drives in reverse, but not in forward.
This is basically the same problem with a Hoover power drive only the forward still drives albeit slowly and a slight "push" to keep it going. There has to be a common core type of drive failure !!
Feb 27, 2007 | Dirt Devil M087700SV Bagless Upright...
Vacuums Logo
113 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
