Question about Dryers
Dryer Start Problem
When the dryer is hot and I press the start button it buzzes and won't kick on. It will start fine cold. There was sort of an electrical type smell as well after trying it several times. My first thought was maybe a faulty start button or maybe a relay????
Deseo instalar el driver para mi cam marca veo
Posted on Feb 28, 2008
    Novelist:
  • 139 Answers
Several things could cause this....depending on the type of buzz you are hearing...it could be a defective motor. Sounds are difficult to describe in text...but if the motor is bad, I would expect it to make a low pitched humming sound rather that an intense mechanical buzz. In this case the motor would also tend to get hotter the more you try, which could cause the smell.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I have and Amana electric dryer when I push the start button it buzzes and does not start
Wild guess the dryer is overloaded, Or too hot and needs to cool down. There are temp sensors that will prevent starting when too hot. You may have drive belt or fan problems exhaust pipe clog.
Feb 28, 2015 | Amana DLE330RAW Electric Dryer
My Maytag DG410 dryer won't start. All that happens when I press the start button is an electronic buzz. Thinking something was stuck, I removed the drum and cleaned the whole thing to no avail. Any...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Maytag MDG2600BWW Gas Dryer
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
My maytag dryer got to hot heating a blanket and now it won't work at all. When u push the power button I feel it wanting to kick in but it won't do anything!! I know nothing about dryers Help...
heatman101
Jul 04, 2011 | Maytag Dryers
GE Heavy duty Dryer will not start when ''start button'' pushed...will make a loud buzz, starts for anything from 10 -20 seconds if I keep finger on the button then goes off I have to keep returning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Sep 02, 2010 | GE Dryers
Start button does not kick the dryer on
Looks like your drive motor is locked up. It has an internal overload switch which cuts power off when motor gets too hot...Replacement of the motor on a used dryer is probably not the best choice as it can be quite pricey..
Jul 09, 2017 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Maytag performa dryer won't run right
bad motor,,should have change it when you had it open,,thats the overload you hearn inside the motor,,when hot it clicks off and when itcool it will run a while than click off...again...need help changing ..
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
112 people viewed this question
Top Dryers Experts
