Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
The media device has either stopped responding or has been disconnected
I recently bought a refurbished Sansa c250 from Woot! It looks very nice and everything but when I open My Computer/Sansa c250/Internal Memory and try dropping a song, a "Error Copying File" pops up and says "Cannot copy [song name].mp3: The media device has either stopped responding or has been disconnected. Is this because I bought a refurbished and it's broken? Or what am i doing wrong?
I am sure my sansa is still connected.
  • 3 more comments
  • SlapHappyPap Apr 03, 2008
    Same Problem too! I got the same device from Woot! It worked once but now I get that error no matter what computer I connect it too.
  • Anonymous Jul 19, 2008
    I have an e260 that I also got from Woot and am having the same problem copying files. The error I got was "The device has either stopped responding or has been disconnected". After googling the problem, I tried the advice from person on a forum having the same problem. The said to try and copy the file to the Root Folder NOT the Music folder. This worked from me. I think the Music folder is somehow corrupt. You can delete the actual Music folder on the device and it will re-create itself. Just wanted to pass this on.
  • eclipse722 Feb 01, 2009
    I just got my Sansa View e250 from Woot.com and it's showing the same error message. I don't understand this. I will try to download to a different file and see if that helps. This sucks.
  • Anonymous Mar 03, 2009
    same problem here, "The device has either stopped responding or has been disconnected". i'm using windows vista, before i had windows xp and never had any problems.
  • Pranay Ramaul
    Pranay Ramaul Apr 09, 2014
    same problem on my phone what the solution
Make sure you're not using the media with another program while you attempt to copy/sync it to your device.
Pretty late response, but meh.
Posted on Aug 02, 2009
Ok i just now had that same problem with the song ******** by Cee Lo Green. It wouldn't download it to my Sony MP3 and that message popped up saying "Sorry but this device has either stopped responding or has been disconnected" I tried redownloading the song from a different site but that didn't work and it was in .mp3 format. So I renamed the song from 'Cee Lo Green - ********' to 'CeeLoGreen - ********' and it downloaded it with no problem. So here's my anwser: try changing the name of the download file, like take out the spaces in the name, and see what it does. It worked for me so I hope it works for you. I hope I helped and I'm sorry if it doesn't work for you I just thought I'd share what I found :)
Posted on Aug 19, 2011
  • RichGamer117 Aug 19, 2011
    Ok so I just had this problem with downloading the song ******** by Cee Lo Green. Whenever I tried to download it to my Sony MP3 a message popped up each time saying "Sorry but the device has either stopped responding or has been disconnected" which neither problem had happened because I was able to download other songs from playlist onto it at the same moment. So I tried redownloading the song from another website to see if that worked and it still wouldn't copy. It was in .mp3 format so I didn't know what else to do so I tried renaming the file. I changed it from "Cee Lo Green - ********" to "CeeLoGreen - ********" and it downloaded straight to my MP3 with no problem. I'm not positive that this will work for you but try renaming the file that you're trying to download (ex: take out the spaces) and see if that works. I hope this helped and if it doesn't I'm sorry and I hope you find another way to fix your problem
  • Pranay Ramaul
    what the solution of this error
I gt the same prob on my sony walkman
Posted on Mar 25, 2008
I am facing some problems in uploading the music lists in my sansa c 250 player. After uploading music from the computer ,all the new songs are added in the music playlists . But after disconnecting it from the computer and refreshing the data base the sansa set continues to play the old music lists without even showing one of the new songs .Also the memory is not full as yet. Please help.
Posted on Aug 03, 2008
Sansa e250 won't connect
1.try formatting your sansa
2.try to copy again..
3.if it does not work tell me what sansa you are using
May 23, 2009 | SanDisk Sansa e260 MP3 Player
Successfully downloading music onto Sansa c250
Here is a link to the manual:
http://www.sandisk.com/Assets/File/Downloads/user-guides/c200-ug-eng.pdf
If you are certain that all of the files are in mp3 format, then your best bet would be to change the USB Mode of the player - if it is in MSC Mode, chnge it to MTP Mode and vice versa - instructions for doing this are in the manual.
-Tha Mp3 Doctor
Dec 31, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Safely disconnecting Sansa C250 from Laptop with Vista
Right click the taskbar and select Properties. Then select Customize - look in past items and see if you find the safely remove hardware option.
-Tha Mp3 Doctor
Dec 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa 250c software
It should be available on the SanDisk website in the support section. You could also call them and order a disk for a fee.
Cheers
Dec 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Looking for sansa c250 mp3 player manual
To obtain the manual for your device, please click on the link below
http://cn.sandisk.com/Assets/File/Downloads/user-guides/80-36-00556.pdf
I hope that helps
Please rate accordingly
Thank you
Computerrep
Nov 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Please help
Follow the link below to obtain the driver for your device..Select your device model and operating system.....
http://www.sandisk.com/DriverDownload/index.asp
I hope this helps..
Thank you
Computerrep
Apr 17, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can't disconnect
instead of dragging and dropping, try moving or copying the files to your player.
other wise i would say just to turn off your comp or player.
hope this helps!
~Rebecca~
Jan 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 unable to sync music from WMP11
The certificate must be obtained by syncing the device to the music service from which you obtained the songs.
Dec 28, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 vista
All right guys, let me teach you a trick involving this MP3. While it is off turn hold on and hold the back button on the face. (Left button of the square) While holding it plug it in and Vista or any other computer will recognize it as a removable drive like a flash drive so to speak. From there make sure it says its connected on the Sansa and then drag and drop what you like in the recommended place. ^_^ Have fun!
Dec 01, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
9,033 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
