Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Error COde "nd"
I keep getting the error code "nd" in the middle of my wash cycle. What does this mean? Also, the washer does not completely drain all of the water out upon completion of the cycle, leaving the clothes wet.
I get the same error code "nd" in the middle of my wash cycle, the washer does not completely drain all of the water out upon completion of the cycle, leaving the clothes wet.
  • 3 more comments
  • purcell11 Apr 07, 2009
    nd in middle of cycle not draining
  • rozzie16 Apr 10, 2009
    I have the same exact problem as Lee Y's and don't use Dependable Appliance Service in Staten Island. The service guy said Speed Control Board was shot and go buy a new machine. Dosen't make sense to my husband and I. Is there a way to fix this? And does anyone know the capacity size? Maytag is offering 50% off the part if you wish to order directly through them.  Not sure what to order, need help.
  • Anonymous Apr 10, 2009
    I have the same problem. Receiving a error code "nd" during my wash cycle. However, I have a MAH6500 washer.
    Having the same error code "nd" problem. Also water won't drain. However, I have a MAH6500 washer.
  • D Crisp
    D Crisp Aug 04, 2014
    I had the nd error code at the beginning of the rinse cycle. I found a small key and a wad of carpit material, very easy fix. The only thing that I could add is that I scooped out of the tub as much of the water as I could unsing a quart sized (aprox.) container, from the tub and removing the clothes, prior to removing the discharge hose from the pump, this cut down the amout of excess water that was spilt on the garage floor.
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
Posted on Jun 28, 2009
  • mdavisx
    mdavisx May 27, 2012
    Thanks for the good advice. We had the same error code on our Neptune washer, and found a rubber band in the pump, just under the flap, like you said. Just to be clear (for the next reader) you have to remove the outflow drain pipe from the pump housing to expose the flapper-value (and under it, the nickel, or hairball, or in our case, rubber band, that is causing the problem.). Thanks everybody for sharing. Definitely an easy fix, and it saved us having a service guy come, since of course he would have replaced both the computer and the sensor and the pump itself, and charged us an arm and a leg!
I just wanted to say thanks! Had the same exact problem with the washer showing the ND code. After researching the issue online and finding this site, I told my hubby the troubleshooting others did and bam! A quarter was in the small chamber right off the pump!!!! Reattached and am so happy and proud to say, she's working like a champ! Thanks everyone! Try this before you call a serviceman! We are completely "fix it" challenged and was able to get it going within a matter of minutes!!!
Posted on Oct 11, 2009
The suggestions here were right on !!! We took out hose off -- and looked in the pump and low and behold there was a piece of metal (dear husband is an hvac mechanic! --hmmm wonder where that came from?!) Thanks a ton for the help!
Posted on Oct 04, 2008
    President:
  • Maytag Master
  • 2,651 Answers
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
Thank you so much for your posts. After reading through I printed off the suggestions and lo-and-behold there was a "Cabelas" token for games that fit like a flapper valve in the piping (my husband first thought it was a valve). Popped it out and my washer works again! Amen!
Posted on Feb 23, 2010
This was very helpful. I had the same problem--washer hanging in the middle of the cycle without draining and "nd" code showing. In my case I had to disassemble the entire drainage pump at the bottom of the washer: a rubber band had gotten wrapped up around the pump rotor, preventing it from spinning. However, it would have torn if I just pulled it through the outlet port, so I undid the inlet port also (use plenty of rags and ease it and the outlet tube out slowly, since whatever water you can't remove from the front is going to come out from there). Then the pump comes out by rotating the whole pump counterclockwise about 90 degrees and pulling up when it can't turn anymore. Then I unscrewed the three screws that hold the pump motor and the liquid enclosure together and had easy access to the rotor.
Posted on Aug 20, 2012
    New Friend:
Great advice here! My wife and I manually emptied the water in the drum, disconnected the lines and tipped it forward. Took off the big panel on the back and then took off the drain hose from the pump. Pulled out a mangled toddler sock (ok the wife was right this time...the washing machine did eat a sock :) Thanks
Posted on Feb 08, 2014
Thank you for the posts. We had to take the rotor pump out and we had a key stuck in there!!
Posted on Oct 05, 2012
3 Suggested Answers
SOURCE:
SOURCE: Maytag Neptune Error COde "nd"
I had a similar problem until it finally gave up draining altogether. I took the drain pump apart and found that a quarter was jammed in the pump after it broke a vain off. I don't know how the quarter got past the basket but this was definitely my problem.
Posted on Mar 29, 2008
I had the exact same problem. nd code (no-drain) at the end of the cycle and when I opened the door the machine was still full of water. I took the back panel off the washer and disconnected the drain hose from the pump. (You're going to get quite a bit of water gushing out at you so be prepared with towels or a shop vac.) At this point you should see a little rubber disc over the end of the section you just exposed on the pump. This is a little drain flap. Just lift it up and you should be able to see into the pump a little bit. At this point I poked around in there with my finger and found a hair pin stuck in the pump! I wasn't able to get it out from this end of the pump so I disconnected the big rubber boot which connects the wash drum to the pump. Then I was able to twist the pump (counter clock-wise) and release it from the washer base. I didn't have to disconnect any wires and was then able to see into the other side of the pump and pull the hairpin out. Put everything back together and it's worked fine ever since. I've never even looked inside a washing machine before but it really was really fairly simple. Now my husband really does think I'm a domestic Goddess. I said he should take me out to dinner with the money we saved on a service call!!
Posted on Mar 18, 2009
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
Getting nd code and load will not drain water after washing and will not go into spin mode. I replaced the drain pump (one vane on pump broke) but still getting the code. I checked and cleaned all hoses...
"nd" means: Your washer is not draining. It can also mean that the unit senses a small clog while draining. Before calling for service, check the following.
1) Turn off the unit and turn it on again.
2) Select only the Spin Cycle.
3) Press the Start/Pause to drain the water.
If it still does not drain, call for service.
So it sounds like it knows its not draining but wants to. If you can hear the pump driving, it is a clog somewhere. If you don't hear the pump driving, it could be the pump has died.
For all you do-it-yourselfers out there, I got this information from the user manual I found at:
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06%5B1%5D.pdf
Mar 24, 2015 | Samsung WF337AA Front Load Washer
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer Flashing Error Code ND; door won't open after turning washer off
The ND error code means NO DRAIN. ,
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 23, 2011 | Maytag MAH8700A Front Load Washer
Nd keeps coming up
The ND error code means NO DRAIN. To see why the ND code keeps coming up the drain pump needs to be checked for a partial blockage.
GENE
Sep 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
I am getting the nd error
you can get help in this matter at appliancerepairplanet.vstore.ca and you can get a sevice manual and help in this matter
Dec 15, 2010 | Maytag Neptune MAH6700A Front Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
3,996 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
