How do I take my modem off standby. I tried rebooted but it didn't work. The cable activity is still off. Does anyone have a manual i can get? thanks, Cable user
  • 492 Answers
Depending on the type, usually there is a button at the top or front of the modem.
Posted on Mar 07, 2008
Ok.....my internet is up and running......and im useing the SB5101 Model...but when i switch it back to my SBG900....it gets stuck on the roadrunner (internet provider) web page.....it works fine with the...
Turn the cable-modem off.
Unplug the AC poewr to the cable-modem.
Turn the router off.
Unplug the AC power.
Reconnect the AC power to both the cable-modem and the router.
Turn the router on -- this off/on sequence should "reset" the cable-modem and the router.
If the router still does not work, replace it.
If the cable-modem does not work, get RoadRunner to replace it, if they want to keep you as a paying customer.
Jun 26, 2011 | Arris SURFboard SBG900 Wireless Router...
I have no internetconnection with my ps3. I have error 80028ea6 Who can help me?
Good day. If your ps3 is not connecting to the internet. Try to do this steps:
1. Check all of the wire and cable from modem to router.
2. Make sure all cables are tight
3. Try to reboot your equipment on this sequence, modem - router - ps3
If these didn't resolve your issue you need to contact your Internet Service Provider to check your connection. Possible the modem is not getting any signal. If your modem is working good then contact the router support to check the settings with your router. But usually your Internet Service Provider will be able to resolve this issues. Hope this information will help you in resolving your connection problem. Have a great day and thanks for using Fixya.
Jun 23, 2011 | Computers & Internet
Internet has stopped working.
Check that the "block Internet activity" button on the top of the router is in "active" mode, not in "standby" mode.
Unplug the AC power from the modem -- that will reset it.
Contact your ISP -- they can remotely & electrnically access the cable-modem, and will trouble-shoot, and, if necessary, will replace the modem, for free.
Apr 23, 2010 | Arris SURFboard SB4200 Modem
Hello just bought a dlink router DIR615 I HAVE INSTALLED CORRECTLY BUT WHEN I TRY TO GET ONLINE MY MODEM I COULD NOT CONNECT
If you have not unplug the power to the modem and router then turn back on the router first then the modem most reviews forget to tell people turn off everything reboot modem router and computer for the DHCP to work properly the switch on cable modems only place the modem in standby mode you must turn off the power
Oct 27, 2009 | D-Link DI 514 Wireless Router (DI-514)
When I press standby button the standby led doesn't turn on
First, make sure you have an internet connection. If so, shut down the modem. Pull out the power cable and Coax cable from the back of the modem. Then first put the power cable in, then the coax cable and then turn on the unit. Restart your computer to verify a connection. Then try to press the standby button. If this doesn't work call your internet provider and they can reset the modem remotely for you.
Good Luck.
Jul 08, 2009 | Arris SURFboard SB5120 Modem
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Jan 29, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
How to flash my dcm425 cable modem
Ive never heard of flashing a modem before. A router you can.
Who is your ISP provider? They can get you a new modem.
Sep 04, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My modem is off
Modem and coaxial cable abnormally connect, or probably loosing power from internet. ask your local ISP
Jun 24, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Ethernet Card
Do a ipconfig at the command prompt and see if you are being assigned a ip from the modem. If not try rebooting the modem with the ethernet connected to modem and computer. then do ipconfig again to see if not getting internet ip, your card or modem eternet is bad. put in a new one and try again.
Jun 01, 2008 | HP PAVILION A6230N DESKTOP PC
Motorola sb5100 surfboard - ps3
Have you rebooted your modem after hooking it up? Each time you move your connection from your modem, it must be rebooted to issue new information specific to your equipment. Also, make sure you haven't pushed the "Standby" button on the top.
Feb 19, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Computers & Internet Logo
23 people viewed this question
Alun Cox
David Payne
David Payne
