Question about Samsung HT-P38 System
Door does not close properly
Only the silver part of the door stays sticking out. it feels like there is something blocking the track
My HT-P38spins to far - the DVDs will not line up correctly in the laser reader - sometimes they do but its getting rare - it rotates about 1/4" to far so the DVD binds and I get NO DISK error help ?
Is their away to re align how far the platter spins ?
Posted on Aug 22, 2010
Did you get your problem solved?
I had the same problem today.  The tech at Samsung said to unplug 10 secs, plug in and power up.  No luck.
Then she said to hold the stop button (little square symbol) for 15 secs.  The readout said INITIALIZING, then GOODBYE and the unit powered down.  I powered back up and still nothing.
Then I powered down and back up while pressing in gently on the silver part sticking out.  I felt something catch and it went back in completely.   I inserted a CD and it's playing fine.
Goes to show you just have to keep fooling with this stuff and experimenting.
Posted on May 13, 2008
Garage door closes almost all the way and then returns to open. Repeated tries will close door. Replaced both sensors, does same thing.
most garage door openers sense if the door hits something while closing. A sticky track can make the door opener reverse if door doesn't ride on the track smoothly. you may need to grease the track or move door by hand feeling for hard movement.
Dec 20, 2017 | Building Materials
GE Adora dishwasher door will not close
Check where the hinges on both sides enter back into the machine as the door closes. Sometimes a little piece of anything can keep the door from closing completely also check to see if anything is sticking out from the back of one of the racks. This also would keep the door from closing. Good luck.
Oct 15, 2017 | GE Washing Machines
Why will door close and open back up?
Something is tripping the safety sensor. Look st see if there is something blocking them. They are located near the bottom of the door track on both sides of the door.
Dec 05, 2014 | Building Materials
Garage door remote will not close door. It only opens it?
IF the wall mounted button works the same way (opens, but not closes), it's probably the infrared beams (located near bottom of both side door tracks) are not aligned, lenses are blocked by something, lenses are dirty, etc.
Nov 22, 2013 | Building Materials
Tracks stick
Could be a bad disc could be dirt on the laser could be dirt in the MD casette. I'd try blowing dust out of them with compresed air. take a close look you might find something blocking the laser reading the disc.
If none of these maybe the Md mechanism is getting worn out...
Jun 10, 2013 | Sony Audio Players & Recorders
Power sliding door closes half way than opens up and does not close
Check for something blocking the upper or lower track. the door is equipped with a sensor that senses that there is something preventing the door from closing and causes the door to reopen.
Feb 16, 2011 | 2001 Chevrolet Venture
The door won't close. The trays seem to be going all the way to the rear but they aren't far enough back for the door to close. Something is wrong
First make sure the trays glide smoothly and one side or the other has not fallen off one of the tracks. Next, make sure the the rear sprayer supply port is hiiting directly into the hole. If you look at the very back you will notice this port hole that needs to be lined up to you adjustable tray when fully slid back. If everything checks out then check the bottom gasket of your door while it is fully open. Check to see if it feels firmly intact and make sure no little utinsils like a chop stick is not stuck down there.
Nov 30, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Sterling frameless bypass shower doors inside door wont stay closed even though have it on th best option setting to do so
Some times it's possible to tweak a roller track (barely bend) at the proper spot to prevent the roller from back tracking past that spot.
Sep 17, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
May 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Samsung HT-P38 System Logo
185 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
