Question about Zebra TLP 2844-Z Thermal Label Printer
Unable to print Zebta TLP 2844.
No response from the printing process. The usually green led light button in the front panel is now red light. What does it mean? When we try to print there is no error prompt in the computer to detect whether the printer has the problem or the computer itself. Totally no response.
  • Anonymous Apr 22, 2008
  • ravindra68 Apr 22, 2008
When you get a red light it means that there is some type of error, either with the lable or the ribbon.
Take a look at the ribbon and make sure that it is properly placed in the grove otherwise it will 'slip' an wont move.
That is the most common problem that we get.
Posted on Mar 14, 2008
I use a TLP 2844 Zebra Printer, and i just cant get it to print. Each time i send a test print, the red light automatically comes on. I've tried the Dumb test to reset it to the manufacturer's...
You have to proceed with the callibration.
It's in the manual.
I think it's as follows.
Switch on the printer while pressing on the feed button.
Wait until the led stays red stable and release the button.
The printer will advance the labels and if everything is correct it will feed one label and the led will turn green.
Now your printer is ready for use with this label
Aug 05, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Using tlp 2844-z
hold the green feed button down intill it flashes 4 time to default the printer and calibrate it
Apr 07, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
TLP 2844 GAP sensor problem (I guess)
I had the same problem. I found out later there was a small piece of label sticking against the sensor, thus blocking the sensor from sensing the end of the label. As soon as I removed the label (open the cover, it is on the top part) it immediately started to work as usual. Hope this helps.
Apr 22, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
These 2 links will help you troubleshoot the problem:
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844-z Flashing Red Light When I Try To Print
When the light flashes red, press the green button once. What happens then?
Oct 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
ZEBRA TLP 2844
plz try to use in another port(if available) or try with another cable
Jun 30, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Tlp 2844 printing issues
try powering off the printer, pressing the green button while powering back up then when u see it blink let go of the green button
May 30, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2742 not printing
Go to printer properties, advanced - tools - commands
and enter: ^DEFAULT
This command reseys the prntr
Cheers
Mar 17, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
998 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
