Question about Dryers
Kenmore Laundry Center #417.90802990
I need to replace the felt drum glides in my Kenmore Laundry Center, (washer/dryer combo). I'm not exactly sure how to go at it, i.e. through the front or the back. Which ever it is, how do I do it? Thank you.
  • 156 Answers
Unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
Posted on Feb 28, 2008
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: on heat in dryer
Bad coil/may be your 220V is tripped,so reset your breaker and re try dryer.The dryer will run on half the power.The other half supplies the current to the heating coil.I'll be happy to help you through this.
Posted on May 21, 2008
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Tip
417.91702000 Broken dryer belt and felt replacement
To get inside the dryer portion you start by removong the top making a note of where the screws mount makes it easier to put back right later but is no big deal. After removing the top you remove the splashplate and then the controlpanel. The panel has quick connects so the wiring will be no problem. Once the control panel has been removed get the front panel off ad remove the drum.
IThese dryers comewith 2 different styles of glides. The drum mounted version and the front panel mounted versions. The glide kit comes with glue also. I have a page which features videos and more on frigidaire dryers. HERE
Laundry center service manual
on Dec 11, 2010 | Washing Machines
The dryer squeaks... loudly! Is it more likely the glide, the felt, or something else?
Good Morning John,
I understand that the dryer on your Frigidaire laundry center, model# FEX831CS, is squeaking intermittently. I also see that you are wondering if it could be the glide, the felt, or possibly something else, that is causing this. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine the exact cause of the squeaking. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FEX831CS Top Load Stacked...
I need to replace a broken knob for a kenmore 24" stacked washer/dryer Model 11108875279
Their are a total of 5 knobs on the control panel for that laundry center i do not know which knob one you need so this link is for the parts breakdown of the control panel http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-dryer-combo-Parts/Model-11088752792/0582/0152000/P0403242/00001?blt=06&prst=&shdMod=
Gene
Aug 11, 2011 | Washing Machines
I have a Kenmore stackable washer and dryer and when ever you turn the dryer off you can hear the drum grinding I can hear pennies in it would that make a difference?
You have front felt glide kit that the drum rides on and also rear bearing in back also that drum rides in. One of these is the problem and they both have to be repaired by going thru the front not the back of the dryer.
Jan 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
May 28, 2009 | Kenmore Dryers
Dryer
That is an accurate description
the drum of all dryers is suspended from a combination of
felt pads at the drum ends
nylon glides under the drum
rubber tired thrust rollers.
the rubber tires wear, and the drum shifts, this pinches and wears the felts, then there is enough space to pinch the clothes in the gap
It is a simple enough fix, and well worthwhile, felts glides and rollers are cheap in comparison to new dryers.
Generically all dryers are pretty much the same, so when you go to the parts store, the felts rollers and glides may be labelled whirlpool or kenmore
they will fit exactly, there are very few that fit very many models.
To do the job
  • UNPLUG DRYER
  • If a top mounted lint screen, remove lint screen and 2 screws under lint screen from top of case
  • with a putty knife or other blunt blade release spring clips at front corners of lid, retaining lid to front panel
  • tilt lid up
  • remove 1screw each side 1/3 way down front
  • disconnect door switch wires
  • remove front panel and door
  • pull tensioner to end of its travel against tensioner spring, and unhook belt
    (Note:: position of belt around tensinoer and motor pulleys for reinstall)
  • pull drum out forwards
  • motor, pulleys, support rollers, felts, and glides can now be inspected
good roller
3d57115.jpg bad roller
7133e59.jpg rollers are in pairs, if one is worn replace both
Inspect felts and nylon glides where fitted, any wear - replace
to replace felts
requirements 2 or more pairs locking pliers(visegrips) hitemp silicone adhesive
  • pull old felt off
  • scrape off old adhesive
  • spread gllue on drum edge
  • secure felt on drum with visegrip
  • pull felt into place, clip with visegrip, pull again clip with visegrips, work around until felt is attached to drum and clipped in place
  • allow glue to set
nylon glides, if fitted replace easily, a central screw, or glue
reassemble in reverse order
Oct 09, 2008 | Frigidaire FSE748GF Dryer
Dryers Logo
1,073 people viewed this question
Top Dryers Experts
Marvin
Marvin
