Question about Marantz Audio Players & Recorders
Marantz Problem Hello, I have a Marantz AV9000/U1B AV pre tuner. It stopped working the other day. I checked the fuse and the transformer in side it, there seems to be multiable low voltage power coming out of the transformer but after that I have no clue where to look. Do you know if there's been a problem with this Tuner and is it worth getting it fixed? Thanks for your help. Gary reinlite@cox.net
SOURCE: Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Posted on Apr 10, 2008
SOURCE: marantz tuner no power
I had the same problem.
Just resolder the primary winding of the transformer on the PCB.
Works fine again
Posted on Jul 30, 2008
SOURCE: How to program pre-sets on a Sony tuner ST-S100L
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Posted on Dec 28, 2008
  • 4234 Answers
SOURCE: Tuner problem
The numbers you list are Marantz numbers. Given this unit's age, there is a possibility that these are germanium transistors which are no longer available. I will look up your specific model's service manual, but it would help to know the location of the transtors in question here.
Keep us posted and look back in a few days.
Dan
Posted on Apr 03, 2009
  • 4 Answers
SOURCE: Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Posted on May 27, 2009
Marantz SR19/U1B 5.1 AV Surround Receiver Unit powers on but will not play audio out of any of the speaker channels. Buttons respond. No further testing could be done with my knowledge.
The receiver could have gone into protect mode as a result of incorrect speaker connection in which case there should be some indication on the front panel.. Check all speaker connections as even a short between wire strands can shut down the receiver output. You may have to open up the receiver to check for open fuses in the output.
Nov 30, 2013 | Audio Players & Recorders
Plugged marantz sr8100 into 230V outlet without transformer. Did this likely cause irreparable harm to receiver?
Hello
If you have plugged in to 230AC with voltage settings was 110VAC, the transformer has been damaged already [opend winding]. If the voltage settings was 230VAC itself, there will be no harm to its internal transformer. Anyway, open it, anc check the fuses. In some cases, fule only will blow out, preventing from furhter damages. I'm not sure about it, but check it. If the fuse only has blown out, and there has no harm; you are lucky I should say. OK.
Apr 07, 2011 | Marantz SR8001
Where would I find the fuse in my Onkyo Audio Video Control Tuner Amplifier?
Please open the top tray and look near to the area of the Main transformer. you will have to find it located beneath the side.
The speaker fuse also can seen here.
Use a multimeter to trace, possible to test the standy by transformer which may not have a fuse. Unless the standby works the main power will not be switched on. so check this out. Good day
Jun 24, 2010 | Electronics - Others
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Whats the difference
a digital tuner has one advantage only,the stations can be pre -set.
a digital reciever uses a pll synsethizer to generate a signal to lock on the station,an analog tuner is subject to more drift,and as well the sensitivity is a hair less,but if you get a tuner with fet front end transistors,it will sound better.
alot of people say that the hysterisis signal is more evident on a digital tuner.
buy an old marantz or pioneer from the 70s.
the marantz 2275 is 75 watts a side and will outdo todays 500 watt home theatre amps.
they do not build them like that anymore.
Aug 22, 2009 | One For All URC-9910 LCD Remote Control
Computer input to Marantz 50 Inch TV
You will need a VGA to HDMI converter, at least $100. Just Google it and you'll find one. One is linked here: http://www.hdtvsupply.com/vga-to-hdmi.html
Aug 16, 2008 | Televison & Video
Stereo connection
Hi spanky
Sorry for the delays in getting back to you. Been busy here this week.
OK. to connect the 2275 to the 1152,there are 2 ways of going about this.
You can plug the pre- out of the 2275 to the power amp-in of the 1152. In doing this you are using the power amp section of the 1152 and the preamp functions of the 2275. Your other gear like CD player, tape deck and so on also plug into the 2275.
the other(better) way is to plug the pre-out of the 2275 into the tuner inputs of the 1152, leaving the volume at about 40% on the 2275 and use the 1152 as an integrated amp. This means you are using the 2275 as a tuner only. When you do this, you will need to use an RCA lead to jumper the pre-out/poweramp-in connections on the back of the 1152, and the 2275 ... L to L and R to R respectively.
I am still wondering why you want to use 2 integrated amps (each having a preamp and a poweramp section) The only real benefit the 2275 brings to your system will be tuner functions. You could just get a tuner and run the 1152 to be an ideal rig.
Let me know what your ideal setup you are wishing to build would have. Speakers, other gear like CD, tape deck, etc.
regards
robotek
Jul 23, 2008 | Audio Players & Recorders
Marantz tuner no power
Works fine again
May 29, 2008 | Marantz Audio Players & Recorders
How to turn on Kenwood KM-Z1 amp with SL16 input
Have you plugged the amp into the AV9000. Check if the outlet you are using is switched or unswitched. Changing the outlet will most likely do the trick.
Jan 12, 2008 | Audio Players & Recorders
74 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
