Check the fuel filter in the fuel tank for plugging. The primer bulb only affects starting. Make sure the muffler is not plugged. If these things look good, try turning the 'H' needle on the carburetor CCW about 1 turn. If this allows the engine to run without the choke, allow the engine to warm up. Then, open the throttle full on and turn the H needle back CW until the engine begins to speed-up, but is still 4-stroking. Correct adjustment is when the engine will smooth out as soon as it starts cutting, but 4-strokes when not cutting. Hope this helps!
