Question about Kitchen Ranges
Ge gas oven with electronic ignition
Why does the oven light by itself
The oven turns on by itself but never turns too hot.  It warms up to probabl about 150 degrees and usually turns off by itself.  Smells like gas. I've had PG&E check for gas leaks and there was none so I think it's the gas range itself
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Yea sounds like you have a bad oven ignitor, tell tale signs are not heating past warm, smells gas, too long to cook, popping noises while cooking. Id replace that ignitor. Although it might appear to "glow" not glowing strong enough
Posted on Feb 28, 2008
My GE gas wall oven lights, gets hot, then keeps turning itself off during baking.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 24, 2010 | GE Ovens
Oven only works when house is cold
all gas range ignitors have to be just hot enough. i would say put an amp clamp meter on it. if it draws over 2.8 amps its probably good. if under that its bad and replace it.
Aug 01, 2010 | Brown Stove Works TTM721-DK Gas Single...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Replaced gas safety valve, burner flame now too hot
    Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
    Mar 26, 2009 | GE Ovens
    Top burners often wont light if oven is already lit
    Hello and welcome,
    If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
    Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
    This will need to be diagnosed hands on at your location.
    But this is the fault!
    Thank you for using fixya.
    Huum
    Please remember to leave a solved rating before you leave!
    Dec 07, 2008 | GE Kitchen Ranges
    GE Oven does not ignite, bute Broiler does.
    Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
    Oct 14, 2017 | GE JGRP20 Gas Single Oven
    GE XL44 gas oven
    hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
    Jun 25, 2008 | GE JGRP17 Gas Single Oven
    GE Oven does not light - no gas smell and no electronic ignition clicking sound
    It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
    If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
    Nov 19, 2007 | GE JGRP17 Gas Single Oven
    Oven won't light
    Probably a bad oven igniter. Remove oven floor then remove flame spreader. Turn oven on and see if igniter glows. If it does and still doesn't light gas, it's probably weak. Replace the igniter!
    If it doesn't glow, remove and take to your parts store. They should ne able to check it to see if it's opened up.. If so replace it!
    Nov 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE oven
    Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
    Jul 31, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kitchen Ranges Logo
    693 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Marvin
    Marvin
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
