Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool refrige indoor fan runs during defrost but switchs off during cooling cycle.
  • Anonymous Mar 24, 2014
    cooling fan rattles
    President:
  • Whirlpool Master
  • 2,651 Answers
WOW. thats not right at all sounds like a pretty good short happening somewhere, remove back panel and look for obvious wiring issue, wouldnt be suprise tats tracedbak to electronic board failure, thats real odd
Posted on Mar 01, 2008
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 16, 2014 | Whirlpool Refrigerators
Have a whirlpool refrig. both sides freezing up even when set on lowest level model # ed5phaxtsoo cleaned coils fan runs allthe time.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
Freezer compartment no longer cools. Continuous defrost cycle?
Good day,
Sounds more like the compressor trying to start and can't.
Pull the machine out, remove the rear cover and see if in fact the sound is coming from the compressor.
Apr 08, 2010 | Whirlpool Refrigerators
Refrigerated does not cool, freezer works
Most units have the cooling coils in the freezer section, then some vents and a fan circulates cold air into the refrigerator section.
If the vents are blocked by food items or ice, then the fridge will be too warm. Also, if the air circulation fan has failed, then cold air from the freezer will not get to the refrigerator.
On a self-defrosting refrigerator, this can be a sign that the defrost timer, defrost heater, or related part has failed. If the cooling coils are packed with ice, then airflow to the refrigerator does not occur.
Typically there is a electromechanical timer that you can see if you take off the lower front panel...this timer switch can be set so the defrost cycle happens when you want (like late at night).
You can also manually turn the switch to start the defrost cycle. Normally you hear the sound of water running and the scorch-hiss sound of an electric heater element touching water/ice when the defrost is taking place. The refrigerator compressor and cooling fan will typically be off during defrost as well.
Oct 21, 2009 | Refrigerators
Bottom working but top fridge barely cool
it sounds like your bottom mount refrig. has a defrost problem. check for heavy frost on the frzr's rear wall. also make sure your frzr fan motor is running.if your fan is running,then check for air flow coming out the air vent in the freshfood compartment. i need a model# to see how your defrost system is controlled.
Jul 15, 2009 | Whirlpool GB2SHDXTS Stainless Steel
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Which is better pulse defrost or adaptive defrost?
pulse and adaptive def actuall work in tandem with one another. what happens is the computer will put the refrig into a short def cycle and test how long it takes the termination switch to open this determines when it is time for the unit to go into a full term def the next time. adaptive defrost looks for the number of door openings and how long it takes for the def termination switch to open during a regular defrost. most units will go into def every -12 hours with adaptive if the conditions are right it can go as long as 2 or 3 days between def cycles. both systems are very relaible and trouble free. the pulse defrost is available on higer end electronic control refrig and is also adaptive defrost system as well. whirlpool also has adaptive defrost only available on their midline units as well as some higher end manual control units.\\
sorry for the defrost class peyton..
Jan 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
