Question about Lands Phones
I have an AT&T Merlin Plus 820D Control Unit. Can I add VOIP lines to the phone call switch? In other words, can a phone call be transferred to a VOIP phone line? How do you set up? Thanks!
    Master:
  • 555 Answers
A manual for your unit can be found here.
This guy was built way before VOIP was ever a consideration. It won't support VOIP switching natively.
You would need a VOIP gateway to do the conversion between digital (your VOIP lines) and analog (your Merlin lines).
Posted on Feb 28, 2008
  • 790 Answers
HELLO!!
THIS MAY HELP YOU
CLICK HERE
How many lines does the at&t bis-10 phone have?
It depends on how the control unit is programmed. The BIS 10 can't be used as a stand-alone phone (as in....you can't connect it directly to a telephone line).
The BIS 10 will work with the following systems:
AT&T Merlin 206
AT&T Merlin 410
AT&T Merlin 820
AT&T Merlin 820D2
AT&T Merlin 1030
AT&T Merlin 3070
AT&T Merlin II (with the proper modules installed)
AT&T Merlin Legend (with the proper modules installed)
Jan 27, 2011 | AT&T Merlin BIS 10 Phone
I HAVE THE MERLIN PHONE SYSTEM 820D2 I WOULD LIKE TO SILENCE CERTAIN NUMBERS FROM RINGING. HOW DO I DO THAT?
Now that's an oldie :-) I have the instructions squirreled away right here
Here's how to program line ringing:
• go to the voice terminal whose line ringing you want to program
• slide T/P switch toward you
• touch a line button (note red lights)
• touch the button again until correct code appears:
RED ON = Ring
RED FLASH = Delayed Ring
RED OFF = No Ring
• repeat this procedure for each line
• return T/P switch to center position.
Carl
Oct 19, 2010 | AT&T Merlin Plus 820D2 KSU Phone
BIS-10 Phone - How to change default line
If you have a "squared" system (each line assigned to a different button), just press a different line button. To change the order of the lines, slide the "T/P" switch to "P" and press the line buttons in the order you want to use them (ie: Line 4, Line 3, Line 2, Line 1).
If your lines are "pooled" you just get the next available line from the pool - no choosing which line you get.
Hope this helps.
Jun 21, 2010 | AT&T Merlin BIS 10 Phone
What is the code to program a Merlin BIS-10 to have only (1) incoming line. I have a 10 button phone and it thinks there are (5) incoming lines?
Enter admin mode:
Slide switch on left (T/P) down to the "P" position.
press the intercom button above TRANSFER
dial the 2 digit extension number you want to modify
Touch the buttons to add/remove the lines.
Green light on means line is active
Green light off means line is not active
Mar 24, 2010 | Avaya Merlin BIS 10 Corded Phone...
Lines 1 & 3 won't break dialtone on Merlin 410
Unfortunately no. The merlin 410 was an early phone system that didn't have much in the way of programming.
Sep 10, 2009 | AT&T Merlin BIS 10 Phone
Can you transfer a call to an outside line on the
Trunk to trunk transfer needs to be turned on for this feature to work.
Dan
Aug 06, 2009 | AT&T Merlin Plus 820D2 KSU Phone
How to hook up a fax machine to a merlin At &t phone system
Fax machine has to be connected to an analog port on your Merlin. Also you have to specified what extension it is in the programming so your Auto Attendant can forward fax calls to that extension. This is a job for a proffesional. Please hire one.
Jun 09, 2009 | AT&T Merlin Plus 820D2 KSU Phone
Merlin Plus. Have two extra line buttons
do you have a manual? the programming code escapes me...you need to remove the lines on that phone. it wont let you program a button over a line button, so you must first remove the "Line appearances" then you should be able to.
Let me know if you need to code for the removal of line appearances....
May 18, 2009 | Avaya Merlin BIS 10 Corded Phone...
Lands Phones Logo
164 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
