Back to:
Tags:
Printers
Generic problem for all Printers
Printer (by 3 users)
posted by maycarranza on Feb 28, 2008
Printer power is disabled.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by sherwoodbrat, posted on Apr 07, 2008
I changed two ink cartidges closed top no power I looked at the back of the printer there is a little yellow light on below the power cord so I know that there is power to the printer is there a reset button
Comment by Guest, posted on Mar 05, 2008
No power to HP Color Laser Jet 2600n Printer
I unplugged power cord from isobar and replugged and also tried plugging into wall socket but no luck. I unplugged and replugged cables too.
Clarification Request
by jhall1793, posted on Feb 28, 2008
Can you be a little more specific about model & such. Was there an event that created the situation?
by gienn, posted on Feb 28, 2008
hi any other info regarding ur problem?
Solution #1
Not Rated (0)
bandana_gyrl
Rank:Guru Guru
Rating: 92%, 121 votes
I would say the most likely cause of the issue is either that the printer is no longer functioning or that it is experiencing power issues. Make sure that the printer is plugged in directly to the wall and not into a surge protector or a power strip. The printer does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on.
Also if this does not help more info like the type of printer, what you have tried, power outages, would really help to solve the issue.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on printer:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
orange light indicates paperjam, but it is not visible...
HP PSC 2175 All-In-One InkJet Printer
I was printing a project in color. After printing three...
Printers
Using a Mac OS X 10.4  with HP Photosmart C3180 First...
Samsung SCX-4216F All-In-One Laser Printer
When copying printing is faded down left hand side of...
Printers
paper and ink lights blinking - no power light flashing at...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
