Mitsubishi WT-46807 46" Rear Projection Television Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My picture is blurry, re-setting the convergance helps
My picture goes blurry about half the time when we are watching it. I have re-set the convergance a couple of times and that seems to correct the problem temporarily.
Anonymous
Level 3:
  • Mitsubishi Master 3,459 Answers
  • Posted on Feb 20, 2010
Anonymous
Mitsubishi Master
Level 3:
Answers
3459
Questions
5
Helped
849789
Points
5558
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
My picture is blurry, re-setting the convergance h - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
The left half of the picture has gotten blurry, with pink, green outlining what seems like 3 different pictures of the same thing. The left half works fine and the HD of direct TV is good on that side. I...
The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
2answers
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
Watching the Masters and the top half of the tv goes double vision with purple and green colors, it is a Mitsubishi 1080HD 2003
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
2answers
Pictures are coming out blurry
On digital cameras it is always best to press the button half way down before taking the picture. This helps the camera focus, thus preventing blurry images. Always, always press the button half way down. Secondly, if you are still getting blurry pictures, there is a possiblity that the sensor in your camera is bad. I don't know how old your camera is or how long you've had it, but you would need to send it for repair, exchange it, or if it's under warranty maybe they'll send you a new one.
2answers
Hitachi 57F500 blurry picture
How can I fix it? The magic foucs goes to two or three lines and goes back to the picture. The sides are blurry, like red and green.
1helpful
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Blurry picture
you probably have a bad convergance board you can get one at partstore.com but if the color is realy out of wack you will need the board it is very easy to install even for a novice unplug the set take off the lower back hte board is on the upper right only one screw and a couple of plugs but first try to adjust the lens have someone watch and loosen the wing nuts and turn the lene,s slowly one at a time i started with the red one you need to have the set on when you do this i replaced the board first works great now
2answers
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
