Mitsubishi WD-65733 65" HDTV Logo
Posted on Oct 08, 2017
40 pixels or white dots constant on screen
Mitsubishi WD-65733 65 in. HDTV Television. White dots have started to appear across the left side of the screen and stay constantly. A few at first and now a month later about 40 dots about 1/20 of a inch in size. It looks like stars against a night sky. I didn't know DLP TVs had this ''pixel'' like issue. What is the issue or solution?
5 Related Answers
Anonymous
  • 5138 Answers
  • Posted on Oct 21, 2010
SOURCE: I just replaced the blub on a Mitsubishi 65 inch
Ballast Board 1-800-638-3328
Anonymous
  • 167 Answers
  • Posted on Dec 19, 2010
SOURCE: I have a 65 Inch
the DLP chip is going bad you need to replace it to correct this issue
Anonymous
  • 1476 Answers
  • Posted on Apr 05, 2011
SOURCE: I have white pixels showing
riddic759546,
Sounds like you have a bad optical engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Anonymous
  • 1476 Answers
  • Posted on May 26, 2011
SOURCE: Hi I have a Mitsubishi DLP TV WD-65733, and two
icfghost,
Your light engine is failing. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which should help you get the parts and remove and replace the bad unit.
hardrocko
Anonymous
  • 1156 Answers
  • Posted on Jul 18, 2011
SOURCE: getting white spots on my
Hi,all HDTV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board and also white spots.
A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens.
The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
Good luck.
Repair dead pixels?
Dead pixels can not be repaired.
The model# WD-52525 you provided is for a DLP TV.
If you are seeing white dots on the screen it is due to a bad DMD chip or light engine. Unfortunately, it is not a cheap fix.
Good luck
www.aaatvservice.com
1helpful
I have white dots all over the screen.
Those are called pixels depending on the manufacturer of the tv they may replace depending on age size and location of the dead pixels
White dots appear on screen
Sounds like your DLP chi is faulty
2helpful
White dots on the right side of the screen
these are called dead pixels if your television is under warranty you should replace it with new one cause dead pixels generated new ones until it will fill up your screen completely.
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
My 65" DLP T.V. has started having small white
Optical-Eng PN# 938PO75020 Encompass Parts Distribution has 5 left in Stock
Price $1,415.51- core fee $300.00 Final Price $1,115.51 1-800-638-3328
PTS rebulit Optical Eng. 1-800-844-7871 Call and ask what they charge.
I have a Mitsubishi WD Y-657 that started out with a single white dot. Now there are over 50. This all happend in a week. I believe they are dead pixels. ?? What to do?
Dead pixels are a problem with LCD screens. You have a DLP set, so this is not possible. I unfortunately don't know anything else about this problem.
1helpful
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
13helpful
2answers
Developing white dots
white Dots appearing on Mitsubishi DLP 1080p. What causes this?
4answers
Little white dots on the screen
dirty lens, dirty mirrors, warped light guides, spider webs and mini-UFOs that fly across the inside can cause what you described.
but 6 months is pretty early for a cleaning but possible.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
