The tone arm may have been forced out of spec to play an entire LP, or the auto cutout function of the player appears to be operating.
If out of adjustment(someone has forced it), the problem can be resolved by loosening the screw that locks the tonearm to its turret, and adjusting the end travel against the distance to the end of the LP you mentioned it wont play. Then of course tighten the locking screw again
Another common problem, is where dried grease between the two small metal plates fixed to mechanism that engage against the center spindle to activate the autostop mechanism. You will need to remove the platter in most cases to get access to this autostopmech to clean away the dried grease and or adjust it.
Good Luck with your listening. Long Live Vinyl :)
regards
Graeme
Was this solution helpful? Show your Appreciation by rating it:
