Question about Gateway Media Center 610XL PC Desktop
Power supply installation in gateway 610xl
How does one install the power supply in a gateway media center desktop model 610xl?
  • 1 more comment
  • micowave Feb 29, 2008
    It is the removal of the casing that is the tricky part on this computer. It is not a standard desktop. The gateway 600xl is more of an all in one where the power supply is in the spine of the monitor stand.
  • aliesighn Jul 29, 2008
    I have a gateway media center 620xl. My problem is it keeps freezing, and cannot get device drives install.
    Keep saying drivers are corrupt of missing. These devices, modem etc, drivers are from the gateway wed site. This problem is with both windows xp & vista os
    I have changed the hard drive, the memory & I have upgraded the bios. Still getting the same problem.
    Any suggestion would be greatly appreciated.
    email address aliesighn@hotmail.com
    Thanks
  • Anonymous Nov 15, 2008
    I have the same problem. My power supply died, and no one will repair this computer not even gateway. where can I find a power supply ?
    Scholar:
  • 93 Answers
To replace a standard ATX powersupply;
remove left hand side cover (ensure power is disconnected first);
disconnect the 20.24 pin primary power plug (big wide white one plugs directly onto the mainboard, also disconnect the 4 pin AUX power plug, looks just like the other one but is a smaller square shaped plug (older P3 boards will not have this)
disconnect all 4 pin power plugs from hard drives/cd drives and aftermarket fans (if any are installed), disconnect SATA power plugs from any SATA devices installed (flat black plug, 4 wires)
disconnect floppy drive power plug (if app) small while 4 pin power plug, once all of these are disconnected, looking at the rear of the computer there will be 4 screws holding the power supply in place, one screw will be more to the centre slightly to ensure you do not put it in upside down, once you remove those screws the power supply will slide right out.. simply re-do these steps in revers for instaling the new power supply
David
Posted on Feb 28, 2008
It doesnt boot up at all , good power,but nothing past the power cord.
Most likely the power supply inside the unit is bad. Try replacing the internal powersupply.If possibe.
Jun 09, 2010 | Gateway Media Center 610XL (610XLMDIA) PC...
Black screen
I suppose you are saying that the computer is powering up, however, you cannot see the video. In that case you have a bad graphic chip or video card. The gateway media centers came with built-in graphic chips. Thus,your system is dead.
You need to replace the system board.
Oct 31, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Power cuts off or does not start
Check the power cord if it is connected correctly, if does then probably there is problem with the power supply or in the motherboard. Try also replacing the power cords of the power supply.
Oct 21, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Gateway 610 Media Center
I would then suspect the monitor.
Sounds like the video card is working.
Try another monitor to see for sure.
Sep 09, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
I have a gateway media center 610xl that has no power.
if you know on how to replace the power supply then do it, if not proceed to bring the computer. or if you have friends can do this, then much better.
Mar 15, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
How do I change the video card in my 610XL PC?
After the side of the case is opened and the computer unpluged and the video to the monitor unplugged, if it has a card already installed , remove the screw holding the card down then pull the old card straight up out of the card slot. Align the new card that you purchased , pushing it straight down into the slot. Install the hold down screw. Reinstall the side . Install the software after hooking  the computer and monitor up.   If you don;t jknow which type of card ,down load a manual and maybe even further instructions from the weblink I provided.
Below it the Gateway support center for your model. All you have to do is to put in your 22 digit serial number.
http://support.gateway.com/support/drivers/dlcenter.asp
Feb 16, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
How do I install a power supply in a gateway 610xl computer?
REMOVE THE CASE AND UNPLUG ALL.THERE SHOULD BE 4 SCREWS HOLDING IT IN PLACE REMOVE THEM.REINSTALL NEW IN REVERSE.RICHARDM69
Nov 26, 2008 | Gateway Media Center 610XL PC Desktop
Gateway 610XL Disassembly
take cover off top of base.- pry off
remove two screws that hold speaker unit, it will tilt out, disconnect cables and remove speaker.
two screws on back of base and then take off back cover.remove sheild cover.
disconnect all cables. 4 screws hold power supply in.
rca connector board has little black button holding it on. pry up and then remove board to access connecters behind.
pull all cables out towards you.
remove 6 screws that hold base to back of screen, pull up tape under where cables go thru hole.
remove base from screen.
take out screws on back of screen. carefully pry all around case to seperate.
remove back, and then sheild. there are a few screws that hold it on.
If your screen was black, then the two inverter boards could be the problem. there is one in the upper left corner and one in the lower left corner. you can by them on internet. match the partnumber, there are 2 diffent ones.
Nov 05, 2008 | Gateway Media Center 610XL PC Desktop
Computer doesnt read the the ethernet is hooked up
Did you fix it?
If it IS a Gateway 610, then just download the intel PRO 100 LAN drivers and install them!
Worked for mine!
Jul 08, 2008 | Gateway Media Center 610XL (610XLMDIA) PC...
Gateway Power Supply
It's not likley the power usage that did in the power supply unless you split the feeds numerous times. The switch should be straightforward, unplug all the feeds paying attention to what you unplug and only unplug what comes from the power supply. It should be a simple matter then to unscrew the supply from the case, remove the old and reverse the operation.
Jan 01, 2008 | Gateway Media Center 610XL (610XLMDIA) PC...
Gateway Media Center 610XL PC Desktop Logo
307 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
