Question about Dishwashers
Hidden control panel not accessible on dishwasher
I have recently installed a Kitchenaid fully integrated consol S series dishwasher model # KUDSO3FTPA with a cabinet panel. The problem is that with the panel lined up correctly with the other cabinets the hidden control panel is under the counter and there is not enough room for my fingers to work the controls. Is the front panel supposed to be installed lower than he other cabinets or is the panel supposed to sit out further into the room than the other cabinets?
    President:
  • 2,651 Answers
No thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Posted on Feb 28, 2008
  • Debbie Hollifield
    Debbie Hollifield Jan 26, 2014
    I just got one like this but I can't "open" the door? Is there a trick? I can't find the answer in the users manual either, lol
I have kdte104dss0 dishwasher. Top rack will not pull out completely. Is there a way to fix this?
It seems that you need to order a adjuster assembly, slide rails for the top rack of your dishwasher. You can follow the below link to order the parts: http www searspartsdirect com model part kdte104dss0 0593 0130000 w1312023.
Jun 19, 2016 | KitchenAid KDTE104DSS Architect Series II...
Why is inside of cabinet wet after dry cycle?
Need to use rinse aid for proper drying. If using rinse aid, might have a bad heater. Run it through a cycle, open it half way through the dry cycle and touch the heater with a wet rag. Should sizzle if the heater is good.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 22, 2014 | KitchenAid KDTE104DSS Architect Series II...
Led lights burnt out
If the problem is the keypad yes it can be replaced they aint cheap so make sure it is the keypad if no one had removed the panel below the door has a service sheet which will tell you how to check the keypad.
Apr 01, 2014 | KitchenAid Classic Series KUDC10FX Energy...
Why was this model discontinued
I doubt it was a good seller, it was 117 percent more expensive than other models like it.
Jan 06, 2013 | KitchenAid Superba Architect Series II...
Control panel unresponsive
open up the inner door shell after powering down the unit from the power source,wiggle and remove and replace all ribbon cable connections on the electronic control panels and any other connections you can see,moisture corrodes these connections after years and removing and re-installing these will sometimes wipe off any corrosion for a better connection to the machine the screws are on the inside of the door to access the control panel
Jun 19, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
I recently purchases a KitchenAid dishwasher model kudsosfrss from a thrift store (I know, silly me). On intallation I learnd why it was in the thrift store. The Normal and Start/Resume buttons are dead on...
8574143 is the part number for the black console control panel which is the part i believe u want,, u may look at it or purchase it at repairclinic.com, searspartsdirect.com, hope this helps let me know
Feb 15, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
KitchenAid model KUDS25SH (Stainless) latch has come loose.
Remove the six or seven screws that secure the entire control panel to the door (screws are located inside of door around the top. Pull out the control panel and the door latch mechanism will be right there for you to work on.
Jan 31, 2009 | KitchenAid KUDC25CH Dishwasher
Plastic film over hidden control panel
Clear packing tape is often effective but in a hot wet environment- it is not permanent, you may have to redo. Clean with alcohol swab first.
Feb 21, 2018 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
2,291 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
