My daughter ran her hands over a lot of keys quickly and now my keyboard does not work properly, here is what happen when I try to type the alphabet:
abcdefgh51230n6*qrst4vwxyz
can it be fixed?
a big thank you
I pressed the number lock and the problem went away.
Thanks for sharing your solution.
Mike
Depends what type of keyboard it is. Try giving it a good shake.
or banging it on the botttom.
Might be worth prising the keys off and vacuuming underneith them
Obg deu certo mesmoooo
For me it was the num lock key indeed! thanks! i thought i had a virus!
Its the numblock key, I just did that
WOW I couldn't believe someone else had the same problem as me !! Thank you for your help it was the number lock but I have a labtop and I had a had time finding the number lock key I had to push the scroll key which is the number lock key but first I had to push a key that has the letters Fn on it in the bottom left hand corner. Thank you so much for your help!!!
Ooops, its unbelivable for me...i was so upset for last 5 days as my 10 month kid made dis hustle for me on my keyboard, my BIG THANKS to you, my problm solved easily with NUMLOK
i cant find the num lock key
I called IBM and it was fixed by simply pressing numlock and shift!
I had the same problem, and it was the num lock, so a huge thanks too!
tanks help same problem karine 1979
i had the same problem what i found fixed it was to hold the power off button for a min
i had the same problem, and i put the numberlock off ; the problem went away.. thanks for sharing...
