Question about Kitchen Ranges
Maytag oven lock light blinking
Lock light is blinking on maytag precision touch control 500 display. When unplugged and replugged, lock light blinks with the number 40 and can hear ticking noises coming from unit, also can not use any functions of oven (ie, bake, broil, clean). Cooktop burners work fine.
  • Anonymous Sep 25, 2008
    I have the exact same problem after we lost power due to Hurricane Ike.
I can't find my model # on my Maytag Coil Electric Coil Precision Touch Control 500 - can anyone help me please?
Maytag sometimes put the model number on a plate that flips up on the back of the control panel.
Sep 25, 2014 | Maytag Kitchen Ranges
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
I have loaded my Maytag Bravos and all the lights blink
Check door switch wiring or door switch or control board
Mar 09, 2010 | Maytag Bravos MTW6600T Top Load Washer
Gas Oven Won't Light
make sure the wire is connected to the ignition(where it sparks)if it is gently clean the sparking surface with a piece of fine sandpaper.Hope this helps,if it still does'nt work you may need to replace this part but it should'nt be expensive and you can do it yourself(usually one screw) ps sorry for the late reply.
Mar 07, 2009 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
614 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
