Question about Nokia N73 Cellular Phone
Lock code for N73
I want to reformat the phone memory of my Nokia N73. When I follow the instruction, the mobile ask for lock code. Unfortunately I do not know my lock code so it ended up to code error. Now I whant to know if or how can I change the lock code?
  • 4 more comments
  • munna9796 Mar 02, 2008
    my emi code is 351851012953700 pls help me find new lock code
  • Anonymous Mar 03, 2008
    My problem with password for miniSD memory card was a bit
    different - I took out card from my phone. Afterwards, when I returned my card
    to my phone, it was password protected, but I had no clue what was the
    password! So, I tried all possible versions - phone lock code, remote lock
    code, pin, pin2, puk, etc. Nothing helped.
    NOKIA people said I set the password when i bought the mobile. Why would I call them if I forgot my password
    (I’m only using one password in my cellphone lock.)
    BUT I NEVER SET any password. I did not even Know that a password could even
    be set for the memory card.
    Now i am stuck. All my data / info are in the mini SD card, ‘protected’ by a
    password that I never even set.
    Any one can help ? Appreciate it.
  • ce221cl Mar 14, 2008
    there is something wrong with the capacity of the phone memory it's always full even though i already erased all the data in it
  • harry123666 Mar 14, 2008
    i setted
  • dilshu Mar 26, 2008
    I didnt put password for my N73 memmory card but now its asking password for opening my card!!! how i can remove the password??
  • Anonymous Feb 18, 2009
    i forgot the code :(
FExplorer Download for S60 3rd Edition (Beta)
  • You will find a file called mmcstore, rename the file to mmcstore.txt
  • Copy that file (mmcstore.txt) to your PC and open that file with notepad.
  • You will find your password in that file; usually at the end of the file will be the password.
Posted on Sep 17, 2009
Your lock code is 12345 (default)
Posted on Feb 29, 2008
  • Nayeem Rahman
    Nayeem Rahman Aug 18, 2012
    but my fone show password Incorrect.....
I need to reformat my phone memory for my N73 mobile phone but I forgot the lock code, its not 12345..
try to format using this code first turn off phone>remove sim and mmc>then press both of thish button >* >3 > calling button >on off switch when phone format it ask country select menu u can select ur country and go on......if ur fault solve don't 4get
Feb 21, 2011 | Nokia N73 Cellular Phone
My nokia n73 is very slow. i want to format it's phone memory. when i press code it ask for lockcode..i gave 12345 and 00000 but it didn't accept....wat should i do?? plz help
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone
1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number '3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
Jan 24, 2011 | Nokia N73 Cellular Phone
Unlock Memory card - N73
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Rate me if this is helpful. Good Luck :)
May 23, 2010 | Nokia N73 Cellular Phone
Nokia n73
reset ur mobile... flash its phone memory... that wud although delete ur contacts and everything frm d fone memory..
hold the call button, * button and 3 button simultaneously while swithin on the mobile... that shud reset ur fone memory... and first it should ask for the date...
Jul 16, 2009 | Nokia N73 Cellular Phone
Password forgotten nokia n73 memory card
After restore setting know My Nokia N73 Memory card is on Password and I am not forget my Memory card password help me
Jul 22, 2008 | Nokia N73 Cellular Phone
Reformating n73
Reformat the phone
To format:
  1. Turn phone off
  2. Hold the following keys WHILE it's turning back on: (3 + * + green call key)
  3. DO NOT let go till it asks you about your LOCATION
  4. DON"T forget to back-up all pictures and videos on the phone memory to the memory card before doing so
Jul 02, 2008 | Nokia N73 Cellular Phone
Phone security code ...
Follow the step
Howto use:
You need two mobile phones.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
second mobile. Install FExplorer on the second mobile phone. Create
the directory E:SystemRecogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345".
Apr 27, 2008 | Nokia N73 Cellular Phone
My phone says memory full. delete some data.
press the following code and your problem will be solved
    *#7370#
it will clean all your phone memory but not the original software
Mar 22, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
441 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
