My DHA-S680 dvd changer will not playback any of the movies I load into the unit. After shuffling through the discs in the sleeve, the changer indicates that no discs have been loaded.
    Brigadier General:
  • 3,614 Answers
The disc may be bad, inserted upside down, or written in a format the DVD player can’t digest. However, if the player behaves like this with all DVDs, including ones that formerly worked in it, suspect a problem with the lens, laser, support electronics, or rotating hub assembly.
First, turn the power off and unplug the unit for a minute or two. Restart it and try the disc again. In a small number of cases, cycling the power like this will reset the electronics and solve the problem.
More likely, though, you’ll need to dig deeper. Try cleaning the DVD player’s laser lens with a high-quality cleaning disc from a consumer electronics store.
If this doesn’t do the trick, check with the player’s manufacturer for support options. Your player will likely need to be repaired or replaced. Its spindle may not be spinning the disc properly, or its laser may be failing to operate within parameters.
Posted on Feb 28, 2008
    Master:
  • 555 Answers
It probably needs a new magazine. The other possibility is that all of the discs are loaded upside down, but I'm sure that's that's not likely.
Cd are not playing proprly playing songs out of order
Turn off Shuffle function in unit to get tracks playback in sequence.
There would be button on remote or player to select repeat/ shuffle function.
Aug 27, 2010 | Sony CDP-CE375 5-Disc CD Changer
Tip
Aunsoft Blu-ray to iPhone 4 Converter-Convert BD/DVD to iPhone 4 With iPhone 4...
With iPhone 4 on hand, do you want to make full use of your Blu-ray disc and DVD disc, and have them playing on your iPhone 4? Aunsoft Studio announced Blu-ray Ripper for Mac as the Mac Blu-ray to iPhone 4 converter for iPhone 4 users to enjoy HD 720p videos. The Mac Blu-ray to iPhone 4 converter has been updated with enhanced iPhone 4 profiles to make it easy operation on iMac/MacBook Pro.
Load BD/DVD movies via 3 methods:
1. Quickly load BD/DVD disc from BD/DVD Rom with one click.
2. Load movies from BD/DVD-Video file structure folder, which are saved as backup copy.
3. Load BD/DVD image ISO, or DVD IFO for particular part of movies.
Convert BD/DVD to iPhone 4:
With the flexible movie loading method, you can rip Blu-ray to iPhone 4, convert Blu-ray ISO to iPhone 4, convert DVD to iPhone 4, DVD ISO to iPhone 4, and DVD IFO to iPhone 4 with perfect video and audio synchronization.
Why choose Mac Blu-ray to iPhone 4 converter?
- Hard burn subtitles to iPhone 4 videos.
- Convert BD/DVD main movies to iPhone 4.
- One click to choose perfect video playback on iPhone 4 with 720p
- Downscale 1080p Blu-ray disc movie to 720p for iPhone 4.
- Upscale SD DVD to HD 720p for iPhone 4 H.264 .mp4.
Download Mac Blu-ray to iPhone 4 converter, and the BD/DVD to iPhone 4 converter will help you remove copy protection for easy playback on iPhone 4. The Mac BD/DVD to iPhone 4 converter also enables you to convert BD/DVD to other formats as you like.
on Jul 06, 2010 | Cameras
Dvd in in player and won't eject. screen reads "loading".
Try unplugging the unit and plugging it back in after a couple of minutes, if cd still won't come out you can unplug the unit and manually remove the cd by taking the outer casing off.
Sep 07, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
Detachaable front panel of alpinetda7558e am/fm cassette receiver
even though it's detatchable you cant get a replacement.
and even if you could it would cost you more than the stereo is worth for me to send it to you
Jul 30, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
I need the wire diagram
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 08, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
CD changer will not mix discs randomly
RANDOM PLAY SHUFFLE M.I.X (has a little folder next to the mix sign. (#5 button) NOT #6
SHUFFLES ALBLUMS AND SONGS
This option randomly shuffles the next disc and songs
More info here if you need it:
http://www.retrevo.com/support/Alpine-CDA-9856-Receivers-manual/id/1060dj492/t/2/
Sep 03, 2008 | Alpine CDA-9856 CD Player
As a CD player - shuffle/random?
The point of buying a 5 disc CD/DVD player is that you can let the machine play randomly through all 5 CD . Where is that button ?
Dec 10, 2007 | Venturer SVP580 Multi-disc DVD Player
Televison & Video Logo
Top Televison & Video Experts
