Question about Cozy (W352E) Heater
The heater will not ignite properly and the heater will not shut off
---The heater will not ignite properly
The thermostat is left at 60 degrees to keep the heater off. When the thermostat is set up to 75, the heater goes on for two seconds and shuts off.
If the heater is left alone, it continues to go on for two seconds and shuts off, over and over, or it may not go on at all. This lasts for 20mins to an hour. Eventually, the heater goes on and stays on.
If the heater door is slapped a few times, the heater will go on and stay on.
--The heater will not shut off
Once the heater gets going, it won't shut off. The thermostat to be turned back down below 70 in order for the burner to shut off.
Note:
There heater's multi-volt generator was replaced last February 2007, and the heater appeared to work OK for awhile: it went on and stayed on when the thermostat was set above room temperature. However, the ignition problem soon returned (the heater had to be banged for the burned to stay lit), and it appears to be more pronounced this fall
  • 6 more comments
  • djchang Feb 28, 2008
    also its a Cozy Wall heater furnace
    I need to correct a mistake, it was not the heater's multi-volt generator it was Pilot generator that was replaced
    Also it's a once side heater
    Pictures here
    http://www.box.net/shared/8dlwlel8g0
    http://www.box.net/shared/l6qyhy3eoo
    can u tell me which one is the high limited wire and what is it
  • Anonymous Oct 03, 2008
    how to test pilot generator
  • apatheticopo Jan 28, 2009
    one night our cozy wall furnace (w355f) stopped working. Being a guy, I tapped on the gas valve (not the shut off valve) and the heater started working again. Problem repeated so I replaced the gas valve. worked fine for a while (days) then problem repeated. Replaced the pilot generator (even though no problem with pilot staying lit). Same thing -- Worked for a while tapping the valve got it working then it stopped again. But then the burner started cutting out. When it came on, it would stay on for 3-4 seconds then off. Not being too many more parts to replace, I replaced the thermostat. Initially it would cycle fine as the t'stat was adjusted. Now, we're back to the intermittant working and the burner cutting out......HELP!!!!! I'm thinking the only piece left to replace is the burner assembly otherwise one of the new parts are bad
    one night our cozy wall furnace (w355f) stopped working. Being a guy, I tapped on the gas valve (not the shut off valve) and the heater started working again. Problem repeated so I replaced the gas valve. worked fine for a while (days) then problem repeated. Replaced the pilot generator (even though no problem with pilot staying lit). Same thing -- Worked for a while, tapping the valve got it working then it stopped again. But then the burner started cutting out. When it came on, it would stay on for 3-4 seconds then off. Not being too many more parts to replace, I replaced the thermostat. Initially it would cycle fine as the t'stat was adjusted. Now, we're back to the intermittant working and the burner cutting out......HELP!!!!! I'm thinking the only piece left to replace is the burner assembly otherwise one of the new parts are bad
    Problem Solver:
  • 14 Answers
Judging by your pics (helpful, by the way) you have a high limit wired into your thermostat wire. Try disconnecting that wire nut connection in front of your valve and hooking the thermostat straight to the top and bottom posts on the valve (eliminating the high limit). If it runs fine, either the connection was poor or your high limit wire is pinched.
Posted on Feb 28, 2008
If you have a programable t-stat, try changing the battery. most of the time that is the problem for that condition.
Posted on Jan 11, 2009
How to reset the thermostat to shut off after 2 degrees/CT87B-4008?
on these thermostats remove the outer ring cover and in the lower right side you will see a slide adjustment. move it i believe left for closer cycles and right for longer cycles. it should be 2* on either side of set point. remember that the fan is not furnace shut off.and turning back and forth will not tell you anything. just set it and see how it works then change it again if you need to
Oct 13, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
I have a customer who has a Warm Morning direct vent propane heater: model DV.203 AMA. His complaint is the thermostat does not seem to work properly. The dial is turned to the lowest setting and it...
Some thermostats have a default lower limit such as 60 degrees to prevent complete loss of heating. The lower limit is not set by the user.
Nov 19, 2013 | Heating & Cooling
Failure ti ignite properly
This may be due to the gas valve being faulty.
Jun 27, 2017 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Goodman GKS9. I have this unit in a condo that I only use sparingly in the winter. I keep the dual thermostats both at 57 and it maintains that tempeature. The problem is that when the thermostat is raised...
The presure switch is breaking down try taking the tubes off and blowing down the switch , or take a small drill bit and clean inside the connections to the pressure switch some times this becomes blocked .
Jan 16, 2012 | Goodman Heating & Cooling
Just moved in yesterday and the Honeywell thermostat is not working properly. the down stairs has diffent kinds but the up stairs rooms have the Honeywell thermostat. we set the temp. to 60 degrees but it...
Sounds like the programming on your thermostat needs to be reconfigured, but I need more information like the Honeywell Model number which can be found behind the front cove, but becareful to unsnap the t-stat properly not to damage the pins that connect t-stat to its base.
Jul 25, 2011 | Honeywell Programmable Thermostat Heater
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
How old is the thermostat? Also there a limit switches at different points on that unit. If you have a volt ohm meter find the round disc like safety's and ohm them out. Take the wires off the disc before testing them. You should have a continuity should be closed they only open if unit gets too hot. Say something like 180 degree's.
A fast way to check out the thermostat is take a small diameter wire take the cover off the t-stat and jump across the R and the W on the t-stat. If the furnace comes on then t-stat bad. Let me know if this is helpfull. Ken
Nov 09, 2008 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
510 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
