I have a Fujifilm finepix J32 and its been working perfectly then yesterday i tried to turn it on and it just says zoom error and the zoom lens come out but go straight back in again and the screens blck with the words 'zooms error' on .
Had exactly the same problem with my fujifilm j32, after reading a few things on the net and definitely couldn't be bothered to waste money and time sending off a camera that cost a few quid I took matters into my own hands!
I turned the camera on and quickly grabbed the lens to stop it retracting again, once it was held out I gave it a good 'wiggle' moving it in all directions fairly firmly!
I then pressed the on/off button again to switch it off and then turned it back on and low and behold it turned on and worked perfectly after!
Hope this helps others cause it could save you a lot of time and money!
SOURCE: zoom error
You lens are tilted? If so, they are out of track. Maybe you bumped or dropped the camera. Try straighten them up with your fingers, very gently.
SOURCE: fujifilm finepix a820 zoom error
This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
Thanks for using fixya.
Testimonial: "thankyou for your advice"
SOURCE: fujifilm finepix f40fd
An update to the initial posting. As a warranty service provider, I can state that physical damage as a result of mis-use is NOT covered under warranty. Lens problems caused by dropping the camera are considered mis-use and are not covered. There is a good posibility that the lens assembly is just out of timing and can be rebuilt, but the cost to do this will not be paid by the manufacturer.
I don't want you to believe that this repair will be for free as it will not.
Regards,
Dan
SOURCE: I just bought a FUJIFILM Finepix j38 less than a
u have a 1 year warranty. i would contact the business u bought it from because fujifilms customer service SUCKS
SOURCE: zoom error on fujifilm finepix j27 camera
fujifilm finepixj27 when you switch on lens comes out then back in again and says zoom error can anyone help please ...
