2004 Honda Accord Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My glow plug light does't always come on first time I turn the key on my 2004 Accord diesel, when this happens the car just turns over and won't start. If I wiggle the key a few times the light comes on and it starts?
dj_relly999
Level 2:
President:
  • Expert 4,070 Answers
  • Posted on Feb 19, 2010
dj_relly999
Expert
Level 2:
President:
Answers
4070
Questions
0
Helped
1065839
Points
207
Hi, there maybe problem with the ignition, the heater trigger on the ignition may be a little loose thats why you have to shake it and comes to contact on a certain time. check the heater relays too for it maybe faulty already. hope this helps
2answers
Glow plug light on my accord 2.2 diesel 04 need it off ASAP
Replace your glow-plugs with the proper ones from DENSO.
Why does my 2004 (Land cruiser) PRADO 3000 Turbo Diesel 5sp- have issues starting when it's cold? It turns over and over does nothing, then when it starts, I get a big plume of smoke, then it idles rough...
glow plugs are activated if look on the dash when you turn the ignition just before cranking and you should see a light that stays on for several seconds then goes out and then you should crank the engine ! sometimes when its really cold or the glow plugs are worn try turning the ignition on and off each time light goes out 2 or 3 times to get more heat on the plugs then start ! if this doesnt work then glow plus and system needs checking !
Glow plug light stays on for a long time
this will happen as it gets colder.. preheater needs to reach temperature before starting..in really cold weather we used to turn the key on and off a half dozen times in order to get these glowplugs really warm enough to start these diesel trucks..
MY 6.0 TURBO DIESEL IS HARD TO START
I drive a 2004 F-350 with a 6.0l. 5 glow plugs are out, have to start on ether when temp is below 40 deg F. CAUTION turn key on, wait for glow plug light to go out, spray approx 3 seconds, start. Should crank about 3-4 seconds then fire off. I work on heavy trucks by trade, mainly roadside service work.
By boeinga1 on Nov 17, 2010 2001 VW Diesel Golf TDI. Car started no problem. Drove to gas station. Stopped for gas. glow plug light wouldn't come on, engine wouldn't start, engine turning but not starting....
i think glow plug replacement needed. ever used starting fluid in cold to start?try this, next time no start, cycle your key and let the light come on, wait till it goes off, turn key again until light goes off, if you have to do this more than 3 times, and it runs fine, replace the glow plugs only then. thank you for choosing fixya.com!
2answers
I have an 1993 Ford F250 turbo diesel truck that won't start. I've been told, that the glow plugs are not warming up. Where are the glow plugs and is there anything I can do to warm them up or fix? Do they...
Are you waiting after turning ignition key on before actually moving key to start position? My diesel I turn key to 1st position;bells and lights;if engine is cold an amber light that looks like a lamp filiment comes on...wait until that light goes out before engaging the starter.
Is there a plug in for a diesel jetta
I don't believe any VW sent to the US in the past 15+ years has come with a plug-in heater. The only exception is if the car was from Canada, or if one was installed afterwards.
If the engine turns too slowly to start, try cleaning the terminals of the battery, if still nothing- replace the battery.
If the engine turns over but just won't fire up cycle the glow plugs a few times before trying to start. Turn the key to on, wait for the glow plug light to go out after a few seconds then turn the key off. Repeat 2 or 3 times before you try to start.
Also make sure you use a fuel additive for the cold months. Look for something with anti-gel on the label.
Honda Accord 2004 Diesel Problem
i had the same problem and it turned out to be a dirty fuel filter,am sure this will cure the problem,ps they are a nightmare to replace,take it to a dealer
2answers
6.0 diesel will turn over but wont start
is glow plug light on when u turn key to on and go off verry fast see how long stay onplz replay
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
