Question about Samsung YP-K3 MP3 Player
Headphone jack point
I get sound from 1 speaker but when i press the jack firmly it works ok. however when i let go and move the sound goes back to one speaker again,its so frustrating can i find some one to repair the problem? i live in county Sligo, Ireland
  • 3 more comments
  • Anonymous Mar 09, 2008
    Also, this is not a headphone issue. I am having the same problem, my previous samsung did the same thing. =\ It does the same thing w/ all headphones.
  • Anonymous Mar 22, 2008
    got this too coming from only the right side of my samsung yp k3 its not the headphones if i twist them around and pull em out a bit i get sound from both earphones but its not stereo its mono, i tried re-soldering the jack but no luck =[
  • Segelhurst Jul 15, 2008
    Tried different earphones, but sound is only coming out of 1 ear. Don't know how to fix it. Anyone??
  • Nattts Sep 10, 2008
    Its exactly the same problem with mine! There seems to be no help at all :( Other than that it works fine, and i dont want to have to get a whole new one!
  • Anonymous Nov 22, 2008
    really damn can it fix by radio shack or a storeĀ
    Problem Solver:
  • 8 Answers
Dont mean to state the obvious but have you tried another set of earphones? ie.. maybe its a problem with the cable
Posted on Mar 01, 2008
  • djermaker Oct 30, 2008
    more than likely the audio jack has become worn and one of the pins is no longer connected to the board properly, however the fact that another user said he soldered the jack and it didnt fix the problem makes me wonder.
    it might also be a problem with the jack input itself and not the connection to the board. inside there are two bits of metal on either side which clasp onto the jack when you press it in, just check to make sure they are seated properly and not pushed too far so as to inhibit proper contact with the jack.
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
Le32d400e sound gone
You might have an issue with the headphone socket where the jack goes---when jack goes in it moves a leaf in the socket to turn off the speakers====try to slightly wiggle the jack in and out===the socket may be cleaned with electronic cleaner.
Mar 14, 2012 | Televison & Video
How do I use altec lansing acs40 with a laptop?
Fairly easy really. You'll need to buy a jack to jack AUX cable. Single point for stereo needed and a headphone jack on the laptop.
The left hand and right hand speakers are slightly different. The right hand speaker only has a cord coming out the back of it and no AUX points.
The right hand speakers has a series of small jack points.
The first hole is the adaptor plug that has to be plugged into mains socket, then the 1st hole marked SPKR has to have a jack to jack cord going from that speaker to the other one. The last two holes marked "A" and "B" give you the option to put two jack to jack AUX sound cables in.
To get it into your laptop, you'll need ONE AUX jack to jack cable and fit it into the point at the back marked "B" and then through the headphone socket on your laptop. You will then have sound.
Make sure to remember to put the system on by the push button switch on the back of the left hand speaker. The speaker system also has another rotary switch on at the front of the speaker.
I've had these speakers for well over 10 years - brilliant sound quality and very durable. Hope it has helped you!
May 04, 2010 | Altec Lansing Multimedia Computer Speakers
In-ear Headphones
Same problem, not a 'speaker problem" from blowing them out. Try just pushing the jack until you feel resistance and maually hold the jack. You should hear "almost all the music and vocals'. Validates the transducers are ok. Some sort of wiring problem shorting to mic.
Jun 27, 2009 | V-Moda Vibe Headphones
The sound cuts off sometimes the wire seems to be the problem...
The wire leading into the headset is likely broken. Usually this occurs at the entrance point of the jack or at the point where the wire enters the speaker, if they are worh repairing, open the speaker and check the condition of the wire. this can be as easy as pulling gently on the wire either side of the suspected break. if the wire is firm then it is likely alright, if the wire stretches, the wire is broken inside and only the insolation is keeping it togehter.
if this doesn't work then you will need an ohm meter and ohm out the cable, remember to flex the cable at the suspected area with the meter on, if the meter drops off you found your break.
solder up the break or if in the case of the jack solder on a new jack.
Hope this is of some help.
Ed
Apr 19, 2009 | Logitech Audio Players & Recorders
No sound
I had this problem as well. I would get sound from headphones but unplugging them I had no sound from the builtin speaker.
When you plug in your headphones it moves a thin piece of metal in the jack which interrupts a connection (this is a good thing) so it can know when to disable the internal speaker. When you unplug your headphones the piece of metal moves back and it enables the internal speaker again.
I was able to fix this by taking apart my x51v and bending the piece of metal a little while the headphones are plugged in so that it will contact better when the headphones are unplugged,
To take your axim apart there are 4 screws on the back underneath the rubber grips that you need to take out. Then you can just slide a finger nail up and down each side to remove the front and back of the casing. The back you will need to swing out from the bottom since it hooks over the headphone jack. I unplugged the small wire that connects the front half of the case to the guts using a tiny flat screwdriver.
Inside on the back, there is a black plastic plate that is held on by 4 more screws. Take that off.
Now you can see the headphone jack. I plugged in my headphones and used a small flat screwdriver to push against the headphone jack on the bottom piece of metal on the right side with the axim face down. You can observe the piece I mean by looking at the side of the headphone jack when you plug and unplug headphones. It moves perhaps 1/32 of an inch.
Your goal is to bend the piece of metal closer to where it is when no headphones are plugged in. The only way to bend it properly is to do it when the headphones are in.
Sorry if this isn't clear enough. I'm not sure if this is a permanent fix or not but it's worked for me.
Jan 04, 2009 | Dell Axim X51v Pocket PC
Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Dec 13, 2008 | Toshiba Satelite A10 Notebook
Headphone jack broken speakers wont work
Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
You can either try removing the blocked part using a Tweaser or get it repaired.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
My technics se hd 51 amp seems to have stopped working. I have a barely audible sound when turned up to full vol. Any suggestions...can I d.i.y. this job ? many many thanks. Technics SE-HD1 Stereo...
please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
Jun 23, 2008 | Audio Players & Recorders
Samsung YP-K3 MP3 Player Logo
64 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
