Question about 2wire 2700HG-B Router (2700HGB)
Tring to bridge my 2wire
I have a desktop that i use with the 2wire and i just got a new desktop with with a wireless card installed i also got a netgear wireless router it is telling me i need to bridge the gateway help me please
  • 38 Answers
Why do you need to bridge?
Can't you use both devices off the one router?
usually to bridge you would need, effectively , 2 extra access points to set as the bridges, they then connect to the other routers, allowing communication between the 2.
I do know 2wire is slightly different but you would still need something to act as a bridge on the netgear end.
I still don't understand why you need both routers running. Connect both your computers to the same router which has the internet connection.
Hope this helps
Tony
Posted on Feb 28, 2008
Unable to connect to home ATT 2wire with new Belkin USB wireless
AT&T 2Wire routers function as both routers and modems. You can disable the router functionality by placing the router in bridge mode. In bridge mode, the 2Wire device functions only as a modem and forwards all incoming traffic to the device behind the 2Wire router. For example, you can use a different router instead of the 2Wire's built-in router by enabling bridging mode -- the router behind the 2Wire device will get the external IP address, and the 2Wire router won't interfere.
Step 1Type "Homeportal/management" (without quotes) into your Web browser's address bar and press "Enter" to access the Management page in the 2Wire router's Web interface.
Step 2Provide your 2Wire router's custom password, if you set one. The router comes with no password set.
Step 3Click "Configure" under Broadband on the Management page.
Step 4Type a period (".") into the "Disable PVC Search" box.
Step 5Set the value of the "VPI" box to "0" and the value of the "VCI" box to "35".
Step 6Set the "Connection Type" to "Direct IP" and click "Submit."
Step 7Click the "Configure Services" link on the Management page.
Step 8Uncheck "Enable Routing" and click "Submit."
Jan 31, 2013 | Computers & Internet
Tring to receive a signal from a 2Wire modem on my dell wireless 1450 adaptor
install or reinstall the latest driver from Dell. Make sure to restart the 2 wire modem. If possible, change the SSID and key and try to reconnect.
Jul 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
2wire wireless usb adapter installation for desktop
elomarcillo1,
You are attempting to install a (brand name) 2wire wireless usb adapter, normally the SBC DSL CD is ONLY what you would use to set up your SBC DSL modem. You should have a specific 2wire CD that you put in your CD Drive when you want to install the 2wire wireless usb adapter. Can you locate this CD?
-ms
Nov 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2wire routor
you need to have DSL service at your house. If you do, reset your modem. tambien it could be that your dsl filters are not installed.
Do any lights in the front light up red?
Aug 23, 2008 | 2wire 1800HG Router (RG1800HG00)
Computer recognizes the card, but configuration utility does not?
Hi
Install the compactable drivers,You can find all the drivers and the manual for your Wireless Adapter here: http://www.2wire.com/?p=331
May 28, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2wire 2700HG-B Router (2700HGB) Logo
271 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
