Question about Mitsubishi WS-65809 65" Rear Projection Television
Convergence issues I have the below model HD compatible TV. I have had for about 5 years with no problems. In the last couple of weeks I have noticed, (especially when watching HD on DirecTV), that the picture appears to fade in and out of focus every 5 to 10 seconds. I went in to adjust the convergence and that is when I noticed it in a big way. If I am adjusting for example the Red convergence, the white grid initially appears fine and in sync. After a few seconds the red will appear below the white grid lines, then after about 5 seconds it merges back into the white grid lines i.e. back into convergence. Same with the Blue adjustment. It only happens on the sides of the picture, about the first 4 grid lines from each side in. Any suggestions are appreciated, and thanx in advance, Brad
    Genius:
  • 1,694 Answers
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
Posted on Feb 28, 2008
Pioneer SD533HD5 repair, blown STK's or bad power assy?
Go back recheck everything 6amp fuse in middle of power supply board that will blow, also solder everything that looks like poor connection pioneer always has a lot of cold solder jionts.CK all pico fuses they are green,yellow look like resistors but are fuses.
Jun 15, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Convergence and lamp problems?
Well I hate to be the bearer of bad news but besides the convergence issues you have a bad red picture tube. Us techs refer to your problem as a 'floating grid' in the red picture tube. More bad news is that the tube is no longer availible. The only solution is to have a professional remove the red tube assembly and ship it off for rebuild. A company called Video Display does this work reasonably and I've sent several to them with great results. It takes about three weeks and the whole repair is very spendy, around $400 to $500. Sorry for the bad news.
Jun 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence Problem
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 13, 2009 | Philips 60PP9202 60" Rear Projection...
PCK520R
This sounds like some of the capacitors have burnt out! (does it stay in line then warm up and go out of line? or is it the other way around?) After 9 years there may be many more problems to come with this model TV Projection TVs have a much shorter life span then say a tube tv! (This could cost upwords of $700.00 to fix!)
Please rate this response to your question
Thank You!
Jan 08, 2009 | Samsung PCK520R TV
Convergence IC upgrade
you should stick with the 110's. the pinout may be the same, but that doesnt mean they will work. Also you need to check all of the large 1 watt resistors by the STK's - if one is bad or out of spec it will greatly effect the picture. Remember, you need to test these OUT OF CIRCUIT.
One more thing, there may be some small Pico fuses or other fuses near the convergence power supply - check all fuses as well.
Dec 18, 2008 | Toshiba 50H72 50" Rear Projection...
Resetting convergence daily on Toshiba 43h70
Hi Mark, tough call without putting a scope to the circuit, either the convergence IC`s are going bad, signal from DCU is going bad (digital convergence unit), or possibly bad solder somewhere in the convergence circuit, I`m afraid your going to need a tv tech for that problem, BMW Rider
Jan 02, 2008 | Toshiba 43H70 43" Rear Projection...
Convergence has to be set daily
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic are going replace them before you have more problems
Dec 12, 2007 | Toshiba 43H70 43" Rear Projection...
RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Oct 05, 2007 | RCA HD52W59 HDTV Projection Television
Distorted picture and multi-color words
ive got the same problem on mine ita a 2001 model and also mine when you turn it on it goes off by itself and wont stay on.also mine has multiple pictures one green and one red almost as if 3d im not sure what it cost to fix it but tvs have come down so much i might just buy a new one. good luck with yours
Aug 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Toshiba model 61HX70 convergence issue
It is a good possibility you damaged something on that PCB that had the IC's, I like to use an upgraded chip the STK394-160e that is designed for HD signal stresses. I dont know why they ordered the convergence board but I suspect it would have been ok, there are also 2 jumpers that need soldering JW10 and JW50 that supply power to the chips and they REQUIRE resoldering or it will fail again. Might try reseating the RED CRT board, check for cables that you may have unhooked to see if they are not seated in their sockets properly, double check every wire you unhooked, Make sure you used a Silicone Heatsink Compound on to the back of the IC's. I dont know what all you unhooked, but check the wires going between the CRT Boards. Check for cracks in the boards to make sure they werent flexed to much. Good Luck.
Sep 09, 2006 | Toshiba 61HX70 61" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
