Toshiba Tv Problem
When set is cold (just turned on ) picture tears for a while.. sometime just seconds sometimes for minute or so.. but rarely does when set warm or ambient temp is also warm.. am i looking at major repair cost?
    Genius:
  • 1,175 Answers
What is meant by "tears"?
If you can find a reputable tech he should be able to reflow solder a couple areas on the set and make your troubles go away.
Posted on Feb 28, 2008
Why is my LG 32LC7D TV taking 5 minutes to have a picture when turning on.?
Likely signs of a issue that is going to only get worse---could be in power supply of set (first place to look) or could be main board or something that it controls.
Kind of like "My car runs rough when cold" it is a issue that is not full blown yet.
Jun 01, 2012 | LG 32LC7D Television
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
Tv picture and sound
Sometimes you just have to shoot the old girl.
Mar 13, 2009 | Televison & Video
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
TV turning on not stable
Hello
The issue you are having it sounds like a software issue with the small signal board
Jul 05, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
Brief Startup Problem
the tv has an intermittent problem in the video circuit and related circuit.it could be some cold solder that needs to be resolder.contact the tech to do the repairs.good luck
Apr 03, 2007 | Toshiba 36A43 36" TV
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
TV pops and shuts off
Its two maybe three issues that your having trouble with. First thing is the convergence. That problem could be a cold solder connection on the convergence IC's or the Ic's have a thermal problem, as after they heat up they go bad. The second is the popping. This could be an issue with the rear channel Audio output Ic intermittanly shorting and shutting down the set, or it could be a bad ground around the picture tubes, or a leaky hi voltage block, or a second anode lead going to the picture tubes could be split. The other common problem with this set is the STR#### regulator IC in the power supply. Now unless your a tech you shouldnt attempt any of these repairs as there is very high voltage in this set and could cause great harm to you. seek the help of an authorized repair shop for Toshiba. Try this # if you cant find one in your area 800-457-7777 Good Luck
Jun 09, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
