Question about MSI K8N NEO2-Platinum (MS7025) Motherboard
Added Opteron 180
To my K8N Neo2 Platinum and would not boot, just single long beeps with about 2 second intervals Any clues??
  • David Burkhart
    David Burkhart Apr 03, 2009
    Computer failed suddenly during use. A slight burning smell was reported. Removed all components except CPU, but was still beeping. Removed CPU and beeping stopped. Replaced CPU with a new one and still beeps.
    Next up is a new MB.
    Anybody need a new, ever so slightly used CPU?
    AMD 64 1.8GHz, Socket 939, $25. Contact David at BurkhartTech.com.
  • 210 Answers
The problem turned out to be a bad memory card. Thanks, Map9966.
Posted on Oct 14, 2009
    President:
  • 2,351 Answers
Remove your system memory. If you have 2 dimms re-seat one at a time with a boot inbetween. Clean the copper with alcohol.
Posted on Feb 29, 2008
Monitor has multiple screen images only after accessing windows 7
When you say "Accessing Windows 7" do you mean installing it? Because I am surprised that your board will work properly with Win 7.
Aug 04, 2013 | MSI K8N NEO2-Platinum (MS7025) Motherboard
MSI K8N Neo V2.0 beep code problem is continous beeps.
That's usually a bad ram stick. Shut down the pc & remove one stick at a time starting with the one furthest from the cpu & work your way down to the first one. When it boots without the constant "beep", you found the bad one! You can also check www.msi.com & look in the support area for a solution if mine is wrong.(I'm never wrong though,lol)
May 16, 2010 | MSI K8N Neo Platinum, 601-7030-010,...
GeForce GTX 260
If you have a PCIExpress port on Mother Board.
Apr 24, 2010 | MSI K8N NEO2-Platinum (MS7025) Motherboard
K8n-neo2 platnum
No on-board video. Yes you need a video card. K8N Neo2 Platinum (supports PCI and 1.5V AGP 4X/8X.
Dec 25, 2009 | MSI K8N NEO2-Platinum (MS7025) Motherboard
ASUS K8N-DL Dual Opteron MB
Sounds to me like you have a bad board/socket 2. Is there a setting in the BIOS to enable the second socket? Only use 1 stick of known good RAM till ya get the problem solved.
Dec 25, 2009 | ASUS K8N-DL Motherboard
Need a manual for a MSI K8N NEO2
Here is the site to download the manual.
Please note that is a .zip file.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=587
Thanks for using Fixya.
Sep 01, 2009 | MSI K8N NEO2-Platinum (MS7025) Motherboard
MSI K8N NEO2 Platinum NOT Posting + No beep + No display
try to test the CPU on another machine ...
or at least remove it and reinsert it.
But if u say that u reseted the BIOS an it still not doing the post, it just could be that the motherboard is out !
It can also be the PSU as u say, but i doubd it ! Try to remove all hard drives, cdroms, etc... to limit the power usage... and see if it passes the post.
U can also try to remove the motherboard from the computer case and put it on an insolating surface and than try to boot (sometimes shorts appeare betwen the motherbord- case - psu)
Jan 08, 2009 | MSI K8N NEO2-Platinum (MS7025) Motherboard
K8n-lr motherboard
1 long beep and 2 shorts beeps indicates a problem with your RAM. If you have more than one RAM chip, remove one of them to rule out a faulty chip. If you only have one chip, remove and reseat it. For clarity, you can find the manual for your board at; http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8N-LR And the Asus general motherboard troubleshooting manual at; http://support.asus.com/images/document/ts/E2437_MB.zip
May 30, 2008 | ASUS K8N-LR Motherboard
Asus K8N-dl - second processor present but not running...
Hi, Mistyman here. All Asus mother boards that have dual channel RAM slot must have equal ram in each slot. In most cases the paired slots are matched by color for easy ID, some are identified by a printed ID on the mother board. With your board you will have to have run all of your RAM for the one CPU. If you have only one stick this must be in slot one. If you are using two sticks then utilise the dual chanel system that ASUS have and use A1 & A3. To activate the second CPU you will need to install matching sticks of RAM in the B slots. both cpu's will need to have the value of RAM to work together properly. CPU one = slot A for RAM CPU two = Slot B for RAM. Goodluck, the ASUS boards are a value product.
Aug 04, 2007 | ASUS K8N-DL Motherboard
MSI K8N NEO2-Platinum (MS7025) Motherboard Logo
162 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
