Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Color How do you auto program the TV to get all cable channels and how do you adjust the color? We do not have the manuel.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
All is done in the menu
http://www.samsung.com/download/Model_Select.aspx?type=TV&typecode=1&+subtype=Projection&subtypecode=103&model=HL-R7178W&fileType=UM
or
http://downloadcenter.samsung.com/content/UM/200306/20030623145817468_P55A_00054A_02_0424.pdf
JUST MAKE SHURE YOU HAVE ADOBY BUT IF YOU DONT THEN WINDOWS WILL HAVE YOU DOWNLOAD IT
Posted on Mar 24, 2008
How long does a TV have to be unpluged before it clears the programed channels?
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 08, 2017 | Panasonic PV-DF2035 20 in. TV/VCR/DVD...
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My 47 inch tv's menu is jacked up i i cant auto program my cable channels, cant adjust bass or treble nothing, not even the brightness or color. Tried using remote and by the buttons on the tv itself can...
It is possible that the TV was hit by a small power surge, and the processor has some garbage in it, and you need to leave it unplug for 40 MIN, and that will reset back to normal.
Oct 16, 2010 | Olevia LT42HVi 42 in. LCD Television
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Lost my tv manual moved house unable to ajust and tune and find freeview channels thankyou
Mark, most tv's nowadays have a osd " on screen menu " that can be accessed via the remote control that came with the tv. after adjusting the set up information, cable/ant, auto program will adjust everything including all channels that are available in your area, excluding if your using a cable box, direct tv, or satellite receiver. Hope this helps, tv's have been made very complicated for quite a while now and every manufacture has a different way of adjusting. Also calling the on line support of the manufacturer via internet or phone might be the only solution.
Jun 11, 2009 | Televison & Video
Conversion to DTV from analog
IF YOUR UNIT HAS AN ATSC TUNER THEN IT IS HD READY. SEE YOUR OWNERS MANUEL. HOOK THE ANTENNA TO THE RF (ANTENNA) CONNECTOR .GO INTO THE MENU AND AUTO PROGRAM CHANNELS. GO TO CHANNEL 5 AND SEE IF YOU HAVE 5.1 OR 5.2 IF SO YOUR DONE.
Jan 30, 2009 | Akai LCT2721AD 27 in. LCD Television
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Program channels
Just Press Menu> scroll or Navigate or Select Auto program, then press enter> (to Move press volume button -minus or +plus,and to enter or OK press TV / VIDEO) then select auto program to automatically scan channel. Choose Air if you use outdoor antenna,if cable choose Cable,whatever the result ,just post so i can assist..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
Jerry Greenberg
Jerry Greenberg
