Question about RCA P61930BL 61" Rear Projection Television
Tv dont work
Picture look like 3-D so i shut the tv off, when turning off i seen a spark from the front where lamps are located ( front of tv at the bottom of screen ). After this the tv will not turn back on? dont know if picture is still 3-D because tv will not come back on.
  • 4 Answers
Check fuse in back of tv behind lower panel right where power cord gose in to tv
Posted on Mar 02, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
Ok so I changed the lamp in my wd 62327 and now I have no picture or sound. The lamp light blinks the turns red and the whole tv shuts off. Any suggestions? Someone said to reset it but don't know...
If issue was different from before you replaced the lamp---remove lamp cartridge and look to see the place where it plugs in that the 2 pin socket the lamp connects to is not out of position or got bent when you replaced the lamp.
A reset if it has it is a recessed tiny button on front control strip up front--those when plugged in will blink (green) for 70 seconds and go out and then set can be turned on.
General: the set will shut down for a lot of reasons-----from a lot of dust inside on the fans (this one should have 3 fans) and I have seen it not allow the set to come up and then shut down---the sets intake a lot of dust thru the front and if the fans get coated the set will detect one or more are not turning at the correct speed, turn the lamp off and shut the set down.
Let me know what you find and give me more information if possible.
Mar 22, 2012 | Mitsubishi Televison & Video
The Tv will turn on and work for 5 min then shuts down
3 lights on front flashing indicates lamp quit. Could be lamp or ballast.
Apr 10, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
57xbr10w pops & sparks under one of the lamps & shuts off
The Lamp (CRT) got shorted / leaky that gets spark / arcing and requires replacement. TV is an old model and I'm not sure that CRT is available any more.
May 31, 2009 | Sony KP-57XBR10 57" Rear Projection...
WD-62525 My tv wont work. new lamp does not work. have tried ever
I had the same problem with my 52". I had the error code of 34(lamp abnormal). I put a lamp in that I knew was good and changed the ballast with one that I knew was good and had 8 caps replaced on the power board(they where not puffed but did them anyways) and still nothing. light came on for 3 seconds and went off again and tv shut down with a red status light. I did some reading on other web sites and found that if the color wheel is bad the tv will not work. I found a light engine on ebay for a 100 bucks used and installed that and now it works perfect.
Feb 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV Magnavox 50ML8105D/17 Problem
I have the same problem my DLP TV would shut off after 30 minutes or less all red LED's. Solution: The fan on the lamp assembly was not turning at the proper RPM (bearing going bad) so it was going into overtemp mode. The original part number was a SUNON KDE1209ptv3 12v 1.3W I had a hard time finding one to match that spec. DIGI-KeyCorp (www.digikey.com) was able to cross reference it to a 3 lead P11034-ND part number (NMB-MAT model fba09a12L).
I Installed the fan and problem went away.
Procedure:
Remove the lamp from the lamp assembly
Remove the back panel.
From the back, slide the main circuit board to the left (loose one screw)
Remove the power interlock on the lamp assembly (2 screws)
Disconnect Lamp assembly cooling fan lead.
Remove the 4 silver slotted screws on the lamp assembly, 2 in the front and 2 in the back.
Carefully remove the lamp assembly from the rear. WATCH the Mirror.
Remove fan, cut leads and solder or **** splice on to the new fan.
Repeat steps for installation
Feb 21, 2008 | Televison & Video
Televison & Video Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
