Question about Whirlpool Calypso GVW9959K Top Load Washer
Will not drain
I have a whirlpool calypso and sometimes i get a code LS and FS. most times it will not drain the water from the basin. can you please help me with this problem
If you have the older model pump motor it is a devil to clean out. the newer one you detach the hose at the U point over the motor itself and pick out the lint build up that stops the pump from spinning and pulling water through.
Posted on Mar 07, 2008
Sounds like you may have the same problems I had with mine. My LS problem apparently happened shortly after I decided to wash this mophead that I used to wash my car with. The type that goes on a stick. It wasn't very large, but apparently it was enough to defuzz and plug up the u-joint. I ended up stripping that piece by constantly trying to drain it. Taking the back off was a pain because the water made this a beast to move. That is also when I learned to have a couple of buckets to catch that nasty water. I ended up flooding my floor w/dirty water. What I then should've done was to check to see that the black drain tube was clear of obstruction. IAfter removing the u-shaped plastic,I found it was jammed w/the cotton mop head threads. I figured that this had defuzzed enough and ran it thru again a few weeks later. It happened again! I realized after checking the black draining tube-looks corrugated that it was filled with dimes, pennies and broken buttons. Of course,I had replaced the ushaped water pump again since it was stripped again. Also,
I strictly wash my clothes with He detergent. If the flowsenor senses that there is too much suds, it'll give the FS code. It's not worth eyeballing the amt. of soap to use. Also, it will probably help to clean your washer out once a month-if you do a lot of laundry. Your clothes will get cleaner especially if there is build-up. I get this from the service dpt. It comes in a white bottle. THey'll know what your asking about. But it's been about 2 years since I've had to do anything with the washer. Maintainance goes a long way for this washer.
Posted on Feb 28, 2008
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
My calypso washer will not work, the flashing light says FL ? Can you help
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
Flood Condition:
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso GVW9959KKL2 sometimes doesnt turn on and sometimes has a code of LS which I just read is a lid switch..we cleared this code but it sometimes still appears and will not turn on?
The lid switch is most likely defective and will have to be replaced. It can be tested using a multimeter or ohmmeter. Check out the video at the link I am providing and see if it helps you out with your problem. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Sep 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Fills with water, but won't agitate or drain.
I have a calypso that fulls with water but will not start it just fills with water and then I will get a FL coded.If it is the pressure switch were would it be? I do not see the part on the parts list.I removed the drain hose and removed most of the water.I have not checked the pump as of yet. the model # gvw9959kq0.please e-mail at rmrmoje@gmail.com with a fix.
Aug 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washer
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
Mar 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso Washing Machine
I have had the same problem, there is too much water in the basin. I actually have a repair man coming over in the morning to replace the pump motor. There is a way to make the pump drain without cycling the washer. I cannot remember the exact process, so I will have to wait until the am to repost the solution (sorry).
Feb 19, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
