My KOGI L7VH 19 in. monitor stays black. The green light no longer turns on. Any suggestions?
    Novelist:
  • 113 Answers
Could the power cable be loose at the back/bottom of the monitor? I'm assuming that you've checked the connection at the wall or surge supressor. And some monitor power cables have a converter "brick" in the middle of the cable - and the cable from the wall may be detachable from the brick. If your monitor power cable is like this, check the connection on the "brick" as well.
Posted on Feb 28, 2008
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Kogi L9CH monitor - black screen
return for a replacement, the screen is broken
Sep 13, 2009 | Kogi L9CH 19" Flat Panel LCD Monitor
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Kogi L9ch 19 in flat monitor
(I posted the latest post.) Change the resolution. (Mine was 1024 by 768, so I changed it first to 800 by 600 and then back to 1024 by 768, and it's back to normal!)
Hope that helps.
Feb 13, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Dell flat panel monitor
It's a problem in the power supply section inside the monitor. It needs component-level electronic troubleshoting.
Jan 16, 2007 | Kogi l4bx-na ko 14.1" Flat Panel LCD...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
