Jvc lt-40fh97 40" LCD Hdtv
13 month old tv. right 2/3's of screen shows colored verticle lines. Left side has distorted view of tv program. Any suggestions?
  • Anonymous Mar 15, 2014
    violet verticle lines on left side of 47 d 7000 tv
    Master:
  • 555 Answers
Press the "VIDEO STATUS" button to cycle through the four video modes (Standard, Dynamic, Theater and Game).
Is the picture distorted the same way in all four settings?
Posted on Feb 28, 2008
  • 1,512 Answers
You need a repair guy for this one.
  • Graeme Ross
    Graeme Ross Feb 28, 2008
    I would be contacting a JVC Service agent direct and express your concern with the very early failure. They will often extend the 12 month warranty if you make a little bit of fuss. Good luck
    regards
    Graeme
Black vertical line on the right side of screen. Color distortion on the right of that.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen shots to defective panels to LCD TVs are given. You can see and compare it to that of your TVs'
Mar 13, 2014 | Mitsubishi LT-40148 40 in. LCD TV
Only showing blue red and black colors
It sounds like a display panel fault. Anyway make it sure. Check the site linked here. It has illustrations and details to faults to LCD display screens. Contact any service technician too. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 11, 2013 | JVC LT-32D200 LCD TV
Sounds like a Tab Issue,Connections are Become Bad on the Inner Connections to the Screen,The Real Fix would be to Replace The Panel
Dec 30, 2011 | JVC LT-37X688 37 in. LCD HDTV
My flatscreen tv is distorted
Speakers can cause problems with the correct display of video on TVs but usuall it only concerns direct view tv. Projectors should not have any problems or flat screens. I think you have a different problem Explain better what you mean by distortion in the JVC. Let me know and I will try to help you.
hardrocko
Feb 06, 2010 | JVC LT-42E478 42 in. LCD Television
I have verticle lines on my Mitsubishi LT-52133. the lines are perfectly up and down and the picture in the middle is good but about 4 inches on the left is dark and miscolored and 4 inches on the left are...
That is not good, it can be as bad the LCD panel is bad which is more likely or the LCD panel inteface board betwwen the screen panel circuit and the main video processor board.
Nov 03, 2009 | Mitsubishi LT-52133 52 in. LCD HDTV
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Mitsubishi LT46-144 LCD Verticle Line Problem
Go to Mitsubishi support page, look at warranties (scroll down) and see if your model is under the extended warranty section. Then if so have a tech repair person come look at the picture and order the parts while you keep the tv. Parts and labor are covered.
Mar 14, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Spot on the screen
This problem is covered by Mitsubishi even out of warranty.
Jan 14, 2009 | Mitsubishi LT-52144 52 in. LCD HDTV
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
