(No, not advertising. Just a good photo of the motherboard, if you slightly scroll down)
Look at the chart below the photo of the mobo. (MOtherBOard) Expansion Capabilities:
A) Two PCI slots (Two PCI Conventional bus connectors. Long white slots)
B) One PCI Express x1 bus add-in card connector.
(PCI Express x1 slot. The longer PCI-Express x16 slot is on top. Then the two long white PCI slots. Then the shorter black PCI-Express x1 slot)
You can use a Sound Card in an available white PCI slot, or if the black PCI-Express x1 slot is open.
Yes, I know, I'm getting to it, lol!
The Onboard Audio -> Intel High Definition Audio, doesn't have an output mixer feature.
My onboard audio - Realtek, (And on an Intel mobo), does.
[ Intel 915G (Southlake) motherboard. Has a Realtek audio chip, ALC860. I use the Realtek Audio Manager. Has Sound Effects, and an equalizer. What happened from the Intel 915G to the Intel 945GCL INTEL? Sheesh! ]
Suggest this if you have an open, available PCI slot,
(Usually only 16-bit. Plugs into a USB port where the contacts are not gold plated, as on a PCI sound card, or PCI-Express x1 sound card. I'm old school, and probably need to evolve ; )
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name
ASUS K8V-VM
Description
VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card
Form factor
Micro ATX
CPU Type
AMD Ahtlon 64/Sempron
Number of CPUs
Single
Socket
Socket 754
Front side bus
800 MHz MHz
Chipset
Memory type
DDR RAM
Number of DIMM-Slots
Number of RIMM-Slots
0
Max memory
2048 MB
Memory speed
DDR400, DDR333, DDR266
Serial Attached SCSI (SAS)
No
Serial ATA (SATA)
Yes
Serial ATA ports
Serial ATA 2 (SATA II)
No
Serial ATA 2 (SATA II) ports
None
IDE Ports
IDE Speed
33/66/100/133 MB/sec MB/sec
Built in SCSI controller
No
Built in RAID controller
Yes
Built in graphics card
Yes
Built in sound card
Yes
Built in network card
Yes
Multiple GPU support
No
Crossfire support
No
SLI support
No
RoHS Compliant
No
AGP interface
No
AGP-slots
PCI-e (PCI-express)
Yes
PCI-e slots
PCI-e type
16x/1x
PCI slots
PCI-X
No
CNR-slot
0
AMR-slot
0
eSATA
No
Bluetooth
No
WiFi
No
FireWire (IEEE1394)
No
Number of FireWire ports
0
USB type
USB 2.0
Number of USB-ports
Number of parallel ports
Number of serial ports
RJ-45 (Ethernet)
PS/2 Keyboard
PS/2 Mouse
Line-out
Line-in
Microphone
Yes
Bios
4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS
Miscellaneous
Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) /
Sempron with the new v6.0 BIOS and above. Processor interface via
2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
v i i i
P5GD1-FM specifications summary
(continued on the next page)
CPU
Chipset
Front Side Bus
Memory
Expansion slots
Storage
High Definition
Audio
LAN
USB
IEEE 1394
BIOS features
Rear panel
LGA775 socket for Intel® Pentium® 4/Celeron processor
Compatible with Intel® Performance Universal FMB 2005
processors
Supports Intel® Hyper-Threading Technology
Northbridge: Intel® 915P Memory and Controller Hub (MCH)
Southbridge: Intel® 82801FB ICH6
800/533 MHz
4 x 184-pin DIMM sockets support unbufferred non-ECC
400/333 MHz DDR memory modules
1 x PCI Express x16 slot for discrete graphics card
3 x PCI slots
Intel® ICH6 Southbridge supports:
- 2 x Ultra ATA 100/66/33 hard disk drives
- 4 x Serial ATA hard disk drives
Realtek® ALC861 8-channel CODEC with Jack-sensing
and Universal Audio Jack (UAJ®) technology
1 x Optical S/PDIF out port
Realtek® RTL8101L LAN controller
Supports up to 8 USB 2.0 ports
T1 controller supports:
- 2 x IEEE 1394a ports
4 MB FWH, AMI BIOS, Green, PnP, DMI2.0, WfM2.0,
ACPI 2.0a, SM BIOS 2.3
1 x Serial port
1 x IEEE 1394a port
1 x LAN (RJ-45) port
4 x USB 2.0 ports
8-channel audio ports
On my i455 all the rear slots are occupied. The front only has 2,5,7, 8 occupied. It works fine that way. I think the rear is more critical than the front to proper paper feeding. Good luck
