Question about HP LaserJet 2420 Printer
HP 2430 part
Hello I need the part number for the holders that hold the transfer roller in place , any help would be very apreciated
    Genius:
  • 3,587 Answers
We have a link on how to fix your own printer through this link(check for search box further down page)
Posted on Mar 20, 2008
Media jam transfer roller
directly below the drum ensure transfer roller properly installed also check the drum unit
Jan 08, 2014 | Konica Minolta magicolor 2430 DL Laser...
HP 4250 print fades on left and right sides after five sheets
third party toners will usually give this type of error- remove the cartridge and replace with HP OEM Toner Cartridge- if the problem is gone the cartridge is at fault. if the problem is still visible you may need to order a maintenance kit to replace the transfer roller.
If after you have changed the transfer roller the problem remains then the issue lies with the contact of transfer roller to drum surface is uneven. tyhe transfer holder plates have snapped or the HVT PCB has failed which will require an On site visit by a Qualified technician.
All above can be completed By Belmonte Business Equipment
Nov 16, 2012 | HP LaserJet 4250n Printer
My hp `2430dtn is printing lighter down the right side of the paper
Fist step check with new cartridge, clean transfer roller, clean Laser scanner assembly, check fuser..
Sep 07, 2011 | HP LaserJet 2430 Printer
After cleared paper jam, HP LaserJet 1320 prints blank pages
Yes you can replace the transfer roller, but check to make sure the roller is firmly seated into its holder and that the springs are contacting the metal shaft.
Good Luck
Nov 20, 2009 | HP LaserJet 1320 Printer
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
Oct 21, 2009 | HP Color LaserJet 2600n Printer
What is the usual maintenance and wear & tear for a Canon Color Imagerunner C3220 copier?
Durables for IRC3220
[1] Waste toner container - 60,000 prints*
[2] Secondary transfer outside
roller (120/230-V)-300,000 prints* actual number of
prints
[3] Transfer cleaning unit 100,000 prints*
[4] Fixing roller 100,000 prints* actual number of
prints
[5] Pressure roller - 100,000 prints* actual number of
prints
[6] Transfer belt - 300,000 prints* actual number of
prints
[7] Drive roller 300,000 prints* actual number of
prints
[8] Primary toner roller -300,000 prints*
[9] Secondary transfer inside
prints
[10] Feed roller (each cassette
holder)
250,000 prints* actual number of
prints
Jul 15, 2009 | Canon Office Equipment & Supplies
Replace the tray 2 pickup roller assembly
The tray two pickup roller is a roller in the front of the tray. Remove tray 2 and place it on a level work surface. Locate and open the cover that is
next to the roller in tray 2.
Pinch the blue latch that is on the left side of the roller. Slide the roller off of the shaft.
Then you can slide the new roller back in.
CAUTION When you install this roller, make sure that it locks into place. Verify that the
roller is correctly oriented, and that the round, black spacer next to the roller is correctly
positioned against the locking pin on the shaft.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | HP LaserJet 2430n Printer
I have a Konica Magicoloe 2430 dl printer. Is it hard to replace the fuser unit?
If your not mechanically incline don't bother to replace. To replace the fuser unit remove transfer belt,back cover,left side cover, two fuser connectors(left side) sensor connector on back. Then remove two screws on top which hold the fuser in place. Then remove fuser very carefully.
Jan 20, 2009 | Konica Minolta magicolor 2430 DL Laser...
LJ 2430 Printing Blank Pages
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Jan 11, 2008 | HP LaserJet 2420 Printer
We have a Xerox 6120 which is mechanically identical to the 2430. It was reporting media jams. We determined after removal and careful inspection that the fuser roller and fuser pressure roller had been damaged by what looked like someone attempting to clear a jam with a sharp object. I cannot speak re: the 2430, but the fuser in the 6120 is not a FRU. The construction of the fuser doesn't tolerate any flaws on either surface. There was more paper jammed in the fuser where we couldn't see it until we had the fuser out of the printer. We are shopping for a new printer as the repairs will cost more than we paid for the printer.
Dec 10, 2007 | Konica Minolta magicolor 2430 DL Laser...
HP LaserJet 2420 Printer Logo
44 people viewed this question
Ben Johnson
