Question about Mitsubishi WS-55613 55" Rear Projection HDTV
TV won't turn on - no power
Hello, I have a 1080 series projector TV from Mitsubishi. It recently turned off on me. It's as if no power is going to the tv. I checked the fuse by the power cord and it looks ok. Before the tv went out, I noticed the on screen volume indicator flicker. There are no blinking lights or anything. Any ideas?
  • 1 more comment
  • dcarva Mar 01, 2008
    Slinteriors, I am sorry I have not written back. I will try to look for the fuses this weekend. My company is moving buildings and I haven't had the time to look. But I appreciate your feedback and I will check out my tv very soon and rate your solution.
    Thanks
  • dcarva Mar 12, 2008
    My exact model is the ws55807. I managed to find the fuses. They are not the normal fuses I amused to seeing. They are little green fuses ceramic. They look fine and don't look burned or broken. I couldn't find the chip fuses.
    Thanks!
    Update: My TV had a fuse locator sticker for 10 fuses. Only one was a typical glass fuse I am used to seeing.
  • Mitsubishi Master
  • 8,617 Answers
Thats the V23+ chassis. There are numerous fuses to check. There are 9 regular fuses they are F9A01,F9A02, F9A03, F9A04, F9A05, F9A06, F9a07 &F9A08. Also there is another Fuse F5A00, F9D00 and there are 2 ceramic chip fuses numbers F9B00 and F9B02. Let me know if you need further info.
Posted on Feb 28, 2008
  • Sonny Berry
    Sonny Berry Mar 01, 2008
    thats quite allright, I understand how a busy schedule is.
  • Sonny Berry
    Sonny Berry Mar 12, 2008
    you will need to check the ceramic fuses with an ohms meter as they wont show any sign of being burned. just check them for continuity to verify that they arent open.
On my Mitsubishi 1080 series the sound won't work with the satellite! I'm afraid I messed something up with the menu set up. Any suggestions?
Did this just happen or were you tinkering with it. Eliminate all connections between the incoming signal and TV. Hook it up straight to the TV. If you are ok then go step by step with your components to reach sound.
Feb 13, 2013 | Televison & Video
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Had power outage, then when power back on in house, tv green light keeps blinking even after unplugging and pressing reset button and attempting re turn on. we use a surge protector, tv is 65"...
This is a solution that was previously posted by Fix-Ya Guru Freetek for the exact same TV and same situation:
http://www.fixya.com/support/t2115048-green_timer_light_blinking_tv_turn
Mar 05, 2011 | Mitsubishi Televison & Video
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Can't loate bool;et for Mitsubishi HD 1080 Series Medallion
it is usually in the Audio settings,sometimes by the CC settings, if you go to the TV and enter th menu from the set, go thru one at a time until you find the spot to turn it off, it is under options or Menu on the remote also, there maybe an SAP Option on the remote itself, but you may have to press another key first like a "Function: Key.
I hope this helps some, if so please give me a good (fixya) rating. Thanks and have a Blessed Day
Apr 08, 2009 | Televison & Video
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
371 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
