Question about Motorola Mobility V220
V3i Have had my razr V3i for 6 weeks - will turn on - but any button that is pushed turns it off - help !!
    Brigadier General:
  • 7,752 Answers
You may need to have the keypad flex reflash back into the phone to make it work again.
Posted on Jul 03, 2008
How can i make a motorola razr v3i accepts sd memory card 4gb
    • 1 Hold down the "End Call" button for several seconds to turn the phone off.
    • 2 Remove the battery cover. Turn the phone over and push the clamp on the backside of the unit. The cover should slide up easily; remove it and set it aside.
    • 3 Locate the memory card slot. It is located directly under the battery under a black cover.
    • 4 Pull out the black cover gently to reveal the memory card holder.
    • 5 Slide and press the memory card into place.
    • 6 Replace the black cover on top of the memory card by sliding it back over the card and pressing firmly in place.
    • 7 Close the battery cover; place the cover on its grooves and push gently until you hear a click.
    • 8 Turn on the Motorola phone. If the memory card was installed correctly, you can save contacts and other data immediately.
Apr 11, 2012 | Motorola Mobility RAZR V3i Cellular Phone
How can i change the forgotten code for motorola v3i??
hey there ...yeah about your forgotten  code of your razr v3....look only forgotten unlock code can be recoverd via security code....that is only if you know the security code....just push the button with ----- on its display when your phone asks for the lock code......then it will change to - enter the security code.....put in the correct security code and bam!! you will change it successfully.....
AND PLEASE VOTE .....HELP US TO HELP YOU BETTER....!!
Sep 10, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Want settings to use internet on my motorola razr v3i
You have to contact your service provider they will send you a push message with the WAP/GPRS/MMS settings.
Regards.
Jul 31, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola razr v3i
there is no problem with yours fone,it is with yours brain go and give yours fone to nearest mobile shop to repair
Aug 09, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Button Failure
Please switch off..remove battery and fix them up and turn it on..it cud help..if it doesnt plz service it at ur nearest local Motorola service station
Happy to help
Have a nice day!
tc
May 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Ploblem with v3i
No matter which way you cut it, the unit requires a flash. You really should go to a motorola service center, but if you must do it yourself, Download RSD lite and go to www.motox.info and download a monsterpack for the v3i. Make sure you check the version of firmware you are running by pushing * # and send at the same time. This is called bootloader mode. The mosterpack for your v3i will start with R479 or R47A depending which version you have. While the phone is in bootloader mode start RSD lite plug your v3i in and click flash. Should take about 15 min
Jan 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
RAZR V3i
have you tried changing you're battery?
Jan 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility V220 Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
