Question about HP LaserJet 2840 Printer
Scanner error 5
I get that message above. What do i have to do, replace the scanner portion?
  • Fredx Feb 28, 2008
    ...and how easy is that to do?
    Thanks much for you suggestions Maggie B...
    I spoke with hp online and pretty much the tech said that the scanner seems to be faulty and may need to be replaced.
    So am weighing that option now.
    Scholar:
  • 41 Answers
Everything I'm seeing related to a 'scanner error' is saying to contact HP for service ...
You could try turning everything off (printer, computer) unplug the printer from the a/c power and the computer; wait a minute or two, and plug it all back in and restart.
Also, after you've double-checked that your cables are not old/damaged (try a new cable that you know is working -- like from another machine) to hook up to your computer -- and to rule out that it's not the computer port, you could try plugging it in to another port and see if you don't get the same results).
If none of that works, I'd check with HP -- if you're out of warranty, make sure the cost of repair is worth it --
Good Luck!
Maggie B
Posted on Feb 28, 2008
Fujitsu fi-6140 Scanner: Error 8 (help?)
Hello Connor,
Error 8 could be displayed due to:
1. Faulty cable connecting Panel PCA & Control PCA. Check the cables, it might have been pinched somewhere or may be defective. You may cross check by replacing the same with another scanner.
2. Faulty Panel PCA. You may cross check by replacing the same with another scanner.
3. Faulty Control PCA. You may cross check by replacing the same with another scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jan 09, 2014 | Fujitsu fi-4120C Path-Through Scanner
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Paper jam message is showing but nothing is jammed in scanner and it will not pull the paper through
Hi
Hope the above info is helpful.
Thank you.
Regards,
Tech Satya
May 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Canon dr5020 c02 error
When the top cover is open you get message C01, when the top portion of the top module is not in position, you get C02 error.
S. Mohan
Mar 26, 2010 | Canon DR-5020 Path-Through Scanner
Dell MFCP 3115cn Error Message
From what I have read, it has to do with the scanner arm is jammed or locked. You may be able to toggle the plastic slider above the scanner glass near the hinge from the locked position. That didn't work in my case, but if you tear the scanner down, you may be able to free it. Otherwise a new scanner portion may be required.
Feb 17, 2010 | Dell Office Equipment & Supplies
My scanner fails to scan documents. It either generates a "warming-up" message OR "sorry, scanner could not be initialized. (Scanner parameter error.)" message.
there are many users facing this same error message.
there are options to solve the issue.the upper part of the printer is scanner.you have to remove that upper portion by removing the screws and internal locks on its inner layer.then check out if any dust is got collected on the scanner lens.the lens is a thin glass layer in the scanner that reads the document which you place on the glass.if the dust gets collected on the lens it will show this error messages.but if after cleaning it shows same message that means the internal board is got faulty.there is a mini circuit board beside the scanner glass.internally.so the upper scanner assembly needs replacement.in the scanner assembly set you get the new circuit board.scanner assembly means not the upper scanner glass it only includes the inner assembly and the circuit board of scanner assembly.the cost of new assembly is near to $40.you can get this assembly at any local printer repair shop.they have it in spare or they can easily get it from nearest service center of the hp company.
thanks.
Nov 20, 2009 | HP PSC 950 All-In-One InkJet Printer
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Epson V350 Install Error
what is the exact error message and extension error?
Dec 31, 2007 | Epson Perfection V350 Flatbed Scanner
HP LaserJet 2840 Printer Logo
119 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
