Question about Mitsubishi VS-55707 TV
Convergence problem The picture is curved on the sides and red and green separate. Is this something I can fix?
    Scholar:
  • 135 Answers
Hi there!
You would need the manual to adjust the convergence. First to correct the curving and then to line up the colours. Not too sure wether you need a service remote or the one that came with the set. If no adjustment takes place when you adjust, replace the Convergence Amp IC'S. Good luck,JUS004
Posted on Feb 29, 2008
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
The picture looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
The colors on my tv have separated, red, blue and green.
This a convergence problem. You maybe able to correct "electronically" by using the remote control and menu setup options. If you cant get where you need to go via remote control. A profession tweak may be needed inside the tv to phyiscally align the colors. good luck
Jun 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Picture shows red/green/blue separatly and the images are curving at the sides
Greetings Mhsfl,
I also have a Mitsubishi rear projection and was having the same issues. You need to adjust your convergence. It is found in the setup menus on the television. What will happen is a big grid will come up and you will adjust the colors seperately until it looks like all white lines. It is something that a novice can do. My husband has actually become quite addicted to fixing the convergence on our television! It will need to be done periodically and particularly if you move your unit.
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
May 05, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Mitsubishi VS-55707 TV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
