My windows vista is charging my mp3 , whenever i connect it the computer says that its installing device driver software , and then its gives me a little note saying that the mtp software is installed but when i open my computer the device does not show up and my windows media player cant detect it. i am really looking forward to downloading music on my mp3 i just cant do it because i cant seem to see it.
The driver is NOT digitally signed so in actual fact they indeed are NOT being installed. You will have to turn of the check digital signature by pressing F8 at Bootup and selecting it. Then you can install it. Install as Administrator, Set the install .exe & run .exe, to Compatability Mode for XP SP 2. You WILL have to press F8 each and every time you boot otherwise Vista will "Block" the driver from loading. There is NO real workaround.
I found this on the Zune technical support (if this does help, be sure to rate my solution please):
Your Zune device is not detected by your computer or the Zune software View products that this article applies to.
SYMPTOMS When you try to use Zune Software, you experience one or more of the following symptoms: • The Zune device is not detected by the computer. • The Zune device is not detected by Zune Software. In this case, when you pause on the device icon in the lower-left corner, you receive the following error message: No Zune device connected • If you restored the Zune device software, the following messages are displayed on the Zune device: Connect Zune to your PC On your PC, open the Zune software and restore the Zune device firmware
THINGS TO TRY To resolve this issue, follow these steps:1. Update the Zune software on the computer. To do this, click settings, click software, click GENERAL, and then click CHECK FOR UPDATES.
If the issue is still not resolved, go to the next step. 2. Restart the Zune device.
To do this, follow these steps: a. Set the Hold switch to the unlocked position. b. Press and hold the Back button as you press the top of the Zune pad. When the Zune device begins to restart, release the buttons.
If the issue is still not resolved, go to the next step. 3. Disconnect the Zune device from the computer, restart the computer, and then reconnect the Zune device.
If the issue is still not resolved, go to the next step. 4. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
If the issue is still not resolved, go to the next step. 5. When you connect the Zune Sync Cable to the connector port of the Zune device, make sure that both ends of the sync cable click into position. Additionally, make sure that the sync cable is not connected to the device at an angle. 6. Connect only one Zune device at a time. If you already have a Zune device connected to the computer, any other Zune that you try to connect will not be detected by the Zune software. Disconnect any additional Zune devices, and then try to connect again.
If the issue is still not resolved, go to the next step. 7. If a full-screen battery image appears when you connect the device to the computer, you must let the device charge for several minutes before the device will start and be detected by the computer.
For more information about how to charge a Zune device, click the following article number to view the article in the Microsoft Knowledge Base: 927348 (http://support.microsoft.com/kb/927348/) How to charge the battery in your Zune device If the issue is still not resolved, go to the next step. 8. If you are using Windows Vista, install the Cumulative update rollup for USB core components in Windows Vista software update. This update resolves some reliability issues in the USB core components in Windows Vista. You will achieve better reliability in various scenarios by installing this update.
For more information about this update, click the following article number to view the article in the Microsoft Knowledge Base: 941600 (http://support.microsoft.com/kb/941600/) Cumulative update rollup for USB core components in Windows Vista If you are not using Windows Vista, or if the issue is still not resolved, go to the next step. 9. Examine Windows Device Manager. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties. b. Click Device Manager. Zune should be listed under Portable Devices. Note If the device was installed incorrectly, Zune may be listed together with a yellow exclamation mark (!). Or, it may be listed under Other devices as USB Device. Double-click Zune, and then click the Driver tab. The current version of the driver that is installed should be 2.3.1035.0.
If Windows Device Manager indicates a device problem, or if the version of the driver that is installed is not the current version, you must update the driver. To do this, follow these steps: 1. Right-click Zune or USB Device, and then click Properties. 2. Click the Driver tab, and then click Update Driver. 3. Click Search automatically for updated driver software. 4. Click Install if you are prompted to do this. 5. After the driver installation is complete, click Close. If Windows Device Manager found the drivers, click Close. If you want to locate the drivers manually, follow these steps:1. In the Zune Properties dialog box, click Update Driver. 2. Click Browse my computer for driver software. 3. Click Browse, locate the \Program Files\Zune\Drivers folder, and then click OK. 4. Click Next. 5. Click Install if you are prompted to do this. 6. After the driver installation is complete, click Close, and then click Close again.
If the issue is still not resolved, go to the next step. 10. Examine the computer for conflicts that involve the USB host controller or the root hub. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties. b. Click Device Manager. c. Expand Universal Serial Bus controllers. d. Verify that no errors appear in the list of USB devices. A yellow exclamation point or a red "X" next to a device indicates errors. If any errors appear, contact the manufacturer of your computer.
For more information about how to troubleshoot conflicts in Device Manager, click the following article number to view the article in the Microsoft Knowledge Base: 310126 (http://support.microsoft.com/kb/310126/) Troubleshooting device conflicts with Device Manager If the issue is still not resolved, go to the next step.
You have to install the software for the mp3 player BEFORE connecting the mp3 player to the computer, or else Windows XP will override the native drivers. That particular Nextar is not compatible with Windows Vista, so you may have a problem if you have a newer computer.
1. Connect your ML648B to your computer with Windows XP or later. 2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.) 3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.(Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.) 4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop. 5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool. 6. Select defaults options and finish the installation by clicking on Close or Finish. 7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
<!--[if !supportLineBreakNewLine]--> <!--[endif]-->
Your computer has to recognize MTP. If you plug it into a Windows Vista computer, it will recognize your device. There are steps you can perform for a Windows XP computer to recognize the device without software. Do a search for MTP and Windows XP for those directions. It starts with Adding New Hardware etc...
hope this helps
Trish
