Question about Epson Stylus Pro 9800 InkJet Printer
Epson 9800 I keep getting an error that states "low paper". Which is meant for low paper on the roll. I have lots of paper left on the roll. The same error comes on if I'm trying to print sheets also. The printer is only 1 week old. Any suggestions besides take it back? Thanks
Low Paper message on the LCD means that the media counter has been turned on and it is now at a point where the printer thinks that there is not enough paper to run a job. Here is what you need to do:
1) Turn the printer off
2) While holding the Pause Button turn the printer back on
3) Scroll down to Paper Count
4) Hit Menu to select
5) Scroll up to off
6) Hit menu again and a star will appear indicating that the Paper Count is off
7) Power down the Printer and then Power it back up
This should take care of it. If you have any other issues, feel free to contact me directly.
Sean McGettigan
sean.mcgettigan@lexjet.com
LexJet - www.lexjet.com
(800)453-9538
Posted on Feb 28, 2008
Epson 4880 incorrect paper source setting
you have to chose sheet paper before sendding the print command.
Apr 02, 2013 | Epson Stylus Pro 9800 InkJet Printer
Paper loading error
hi the sloution to the problem is that to go ahead and try to reset the printer and it will definetly work ,
if you get stuck on some problem try to get in touch with me on fixya
Jul 22, 2009 | Epson Stylus Pro 9800 InkJet Printer
7800 epson not printing right
yur black ink has dried compltly.... i think yu have 3 blac catridges.. replace 1 of it.. i meant refill it.! it will work!
Jul 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Hope that the manual contains everything you need from nozzle check to sensor errors.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Sensor error in the Epson stylus pro 9800
sounds like you need a new sensor. call tech support
Dec 10, 2008 | Epson Stylus Pro 9800 InkJet Printer
Stylus pro 9800
you have left it on sheet feed what you need to do is press the button on the top which is furthest to your left until it shows the paper until the led panel shows a pic of a roll of paper with scissors
Oct 06, 2008 | Epson Stylus Pro 9800 InkJet Printer
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Borderless error with 44' paper
Are you setting up a custom paper size each time? Check out page 91 of the 9800's user manual... it has a table of recommended custom paper widths for borderless printing.
Feb 23, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson Stylus Pro 9800 InkJet Printer Logo
146 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
