Question about Sirius STILETTO 100 MP3 Player
Stiletto 100 Lost Left Channel
My year old Stiletto seems to have recently lost the left channel. I do not have a home docking station, but using just the headset or car kit I only get audio on the right channel. Any help or is this year old $150 radio more of a piece of junk then I thought it was?
  • 5 more comments
  • Anonymous Mar 22, 2008
    I too lost a channel, but I believe it was probably due to having it my tight jeans pocket when sitting. The headphone jack probably bent the internal connector. I called Sirius and they sent me another one since it was still under 1 year extended warranty. Unfortunately, there was no way to transfer my 80 hours of recorded content. :-(
  • wgator82 May 09, 2008
    ear phones lose left channel when fully plugged in. you must pull the wireplug out just a little until you get both channels. not a permanent solution because the plug can jiggle free and you get no sound.
  • Anonymous Aug 21, 2008
    Sirius is terrible. Don't buy it.
  • HackMaster Sep 28, 2008
    I to have this same problem. Unfortunately, I am not under warranty. It was quite a shock to find this issue as I rarely use it with headphones. My issue is temporarily fixed by pulling the cord for the headphones back behind the device and taping it. This is defiantly an internal device issue and can only be solved by replacing the device's jack.
  • Anonymous Oct 30, 2008
    Tried the taping and partial insertion methods, lasted about 1mo. before total failure.How does one get inside to replace micro jack?
  • ab19419 Nov 24, 2008
    had 2 stilettos and both headphone jacks broke. the first was under warranty but this one is out of warranty and they can't tell me where to go to get it fixed - they just want to sell me another stiletto! i'm very disappointed.
  • rshaar69 Nov 29, 2008
    Stiletto only plays audio out of one channel , if docked or with headphones. If I pull out headphone wire part way i get audio in two channels.
Mine lost the left channel then the next day lost all the channels. I cAN'T FIND A FIX EITHER
Posted on Feb 29, 2008
Weather station peeps
try the manufacturer's website . we do not know what you have
Oct 05, 2017 | Home
Aux jack not naking contact with left channel.only the right channel is coming thru speakers
some time it happens to some mp3 players.......... once it happened to my Ipod............at first I thought that it can't be solved.... but when I rebooted the system it began to sound through the both of two speaker..........
Nov 29, 2010 | Sirius STILETTO 100 MP3 Player
I've had my stiletto for several years and not had a problem. The screen is now blank and won't work in any of my docking stations.
I am having the same problem. Sirius must've sent out a bug cause many stiletto users are coming forth. Mine stopped working about 1 month ago as of today March 26. Sirius Representative told me today that they are being discontinued.
Mar 11, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
Stiletto 2 volume in car is lower than regular stations
Try increasing the volume on the stiletto itself.
Mar 27, 2009 | Sirius STILETTO 100 MP3 Player
Sirius Stiletto 2 Problem
That's one of several problems my Stiletto 2 has. The only solution I've found is to "reboot" the unit. You'll have to remove the unit from the cradle, pop the back off, and remove the battery for a few seconds. Then put everything back together and power it up. It will take a minute or two, but once it reboots it should be fine.
Aug 15, 2008 | Sirius Audio Players & Recorders
Stiletto 100 sound only comes out of 1 channel
The "one earphone only" problem is common to many Mp3 players. It is not fixable, and the entire player must be replaced. Attempting to replace the headphone jack and assicated circuit yourself can cause major damage to your player. I know you don't like this answer, but it is the only honest answer.
May 07, 2008 | Sirius STILETTO 100 MP3 Player
Lost channels
Try to raise your signal level by adding an amplifier to your antenna or adding height to your antenna. If your signal goes too low for some reason the box erases weaker stations. Sometimes it just relocates them to a different channel number so make sure you use channel up and down first to see if it relocated a weaker channel by itself. Look for channel numbers you don't recognize and when it locks in sometimes it will relocate them back to the original station. Hope this helps, Russmann.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Usb connection on sirius stiletto 2 to pc
I had a sync problem with the Stiletto 2 (SL2) and was able to resolve it by the following procedure:
Click "Start"
Click "Run" > Type "devmgmt.msc"
Click "+" next to "Other Devices"
Note: You should see a question mark and exclamation point next to "Stiletto 2"
Right click on "Stilleto 2" (to see menu); then, left Click "Update Driver."
Follow the steps in the windows hardware update wizard.
Apr 07, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Audio stuck on high
You cannot adjust the volume when the stereo cord is plugged into the back of the dock. Instead, plug the stereo cord into the front headphone jack of the dock. You will be able to adjust the volume then.
Mar 11, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Sirius STILETTO 100 MP3 Player Logo
124 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
